Jets
Discussion in 'General VFR Discussions' started by Jeffb, Aug 27, 2014.
  1. Jeffb
    Jeffb New Member
    Hey guys,
    Need help. I am cleaning my carbs on my 86 700. While spraying thru the slow jet I couldn't blow thru. Second one I could blow thru, 3rd one I couldn't. Not sure which is right.
    Thanks.
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Are you talking about the circuits with the jets in place or the jets them selves? Either way there should be fuel moving through there, so if you can't even blow through it there's a problem.
  3. Jeffb
    Jeffb New Member
    I am talking with jet removed and trying to squirt carb cleaner thru them. One I can spray thru and the next 2 I cant. Tried blowing air thru and no go.
  4. Jeffb
    Jeffb New Member
    Sorry, thru the jets themselves.
  5. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Going to need something to poke through there. I think someone once said a guitar string would work. But also a set of acetylene torch nozzle cleaners will work if you're careful.
  6. Jeffb
    Jeffb New Member
    Sweet, thanks will try.
