Is this a Rivet master link?
Discussion in 'Mechanics Garage' started by morj80, May 12, 2007.
  1. morj80
    morj80 New Member
    Portland, Or
    Could've sworn there was a clip on this master link. Had new chain installed in Feb at dealer, called them they said it shouldbe a rivet master link. I'm not really familiar with them, only the clip type. I adjusted the chain a while back and could've sworn there was a clip on there, cause I used it as a point of reference when insepecting the chain.
    I just noticed it was gone(or never there) today when I was going to adjust it. The plates are tight wont come apart. I've been riding it daily for the past few months.
  2. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    ITS a weird kind of rivet job - but would need a bigger pic of it to be sure
  3. morj80
    morj80 New Member
    Portland, Or
    Do you think they f'd it up, and put the clip on also? Cause I saw that the model chain I got from them comes with a clip and a rivet master link.
  4. Gatekeeper
    Gatekeeper New Member
    That is a poor job of quad staking. There is a tool to do it so it doesn't look like it was done with a cold chisel. I would replace that link because of the stress cracking that can occur with that much deformation. It wasn't a clip type link. The hollow pins are for the rivit expanding die. A clip type would be a solid pin with a groove cut in it to retain the clip.
