Is there any GOOD reason to disable the fan?
Discussion in 'Mechanics Garage' started by bernside, Apr 21, 2010.
  1. bernside
    bernside New Member
    Eastern NC
    Checked my fuse box for the first time and found that the fan fuse was missing.
    Is there any possible reason for the PO to have done this?
    There was a spare in the spare slot so it was not for lack of a fuse.
  2. zielarz
    zielarz New Member
    detroit
    So what u saying is that your fan dosent run?....I can tell u that u need a fan big time....mine fan was running non stop but I wire it correct and it kick in whenever bike gets hot
  3. Rchecks
    Rchecks New Member
    Summerville, SC
    one reason i could think of is he was about to put his hand in the moving blades and figured pulling the fuse 1st was good idea. or it could be smoked and blowing fuses and he gave up replacing them?
  4. mello dude
    Romania
    Stupidity?
  5. bernside
    bernside New Member
    Eastern NC
    :biggrin: that was my first thought.
    I guess I will have to test it and make sure it works like it should.
  6. dizzy
    dizzy New Member
    MN
    At least he didn't 'roll up' a stick of chewing gum tinfoil in place of the fuse. Several years ago I worked on a GL1100 that literally smoked the wire harness and found the PO had pulled that antic.
