installing new clutch - problems
Discussion in '3rd & 4th Generation 1990-1997' started by SAC750R, Feb 10, 2009.
  1. SAC750R
    SAC750R New Member
    So I got my new clutch kit today and went to install it.... 9 friction and 8 steel plates, went to put that center bearing in and install the cover and is a big gap..
    Am I missing something?
  2. Jimtt
    Jimtt New Member
    Chicago area
    OK, do you have a tech service manual? If so I can help you.
  3. SAC750R
    SAC750R New Member
    No I don't, I figured since I have replaced clutches on the ninja I had before it would be straight forward process. Usually the basket cover just slips on over then i install the springs and it's done.
    Usually the the basket cover would install without any problems, never had a gap between the cover and the friction plate before.
    Could the clutch not be disengaged? Never really dealt with hydraulic clutch before.
    Another thing, clutch lever won't pull in anymore...is this normal? Did fine before I removed the old cluthes.
  4. betarace
    betarace New Member
    Middleburg, VA
  5. SAC750R
    SAC750R New Member
    solved...not sure what it's called, but the thing on the other side of the engine that the clutch line is connected to, the little plunger thing was stuck...
  6. Slothrop
    Slothrop New Member
    northern lower Michigan
    clutch slave cylinder
  7. SAC750R
    SAC750R New Member
    Thanks for the manual, should come in handy.
