Increase displacement?
Discussion in '6th Generation 2002-2013' started by bruckner, Oct 30, 2006.
  1. bruckner
    bruckner New Member
    Some had been expecting a larger capacity engine in the 2007 VFR, I was wondering, out of pure curiosity, whether anyone had attempted to increase displacement on a VTEC V4 through boring/stroking or both? I searched through the threads and couldn't find any references to such a project being undertaken.
    Regards,
    Bruckner
  2. KC-10 FE
    KC-10 FE New Member
    Dynamo Humm makes a big bore kit but I don't know anyone who has one.
    http://www.dynamohumm.com/Scripts/prodList.asp?idCategory=20601
    I could give a crap about more power. The VFR is not underpowered. If you can actually ride this bike to it's limits on the street, you are a much better person than I am. Give me a VFR that weighs 450lbs with the same power it has now over 130HP weighing 530lbs any day.
    KC-10 FE out...
    :plane:
  3. bruckner
    bruckner New Member
    I guess I should have stressed with more clarity that I was asking this out of curiosity, I didn't mean to start a debate on whether or not the stock motor makes enough power, I'm glad you're content with your VFR's performance. Thanks for the note anyway, I will look up this tuner.
    Regards,
    Bruckner
  4. KC-10 FE
    KC-10 FE New Member
    I wasn't taking a shot at you & I apologize if you took it that way. I was writing a broad generalization to all VFR riders.
    I'm thinking it will be in the neighborhood of $3000 to actually put that kit in a bike.
    KC-10 FE out...
    :plane:
  5. Sepp
    Sepp New Member
    Ha ha ha... A big bore kit will cost you the kit and the machining, and disassembly-reassembly labor, and the ...etc., etc., etc. Pretty soon the cost is over the face value of the bike. Hell, you may as well buy a bigger bike! There is some replacement for displacement. Better breathing! See my post. Try it - it's cheaper and you'll be satisfied with the results...unless you're only concerned with numbers on a dyno chart for the sake of bragging rights.
    You can do it in an afternoon.
  6. bruckner
    bruckner New Member
    Got your thread Sepp thanks.
    How about fitting an ST1300 V4?? That would be fun!!
    NOTE: No need to mention it won't fit or that it won't make financial sense, I was just k-i-d-d-i-n-g, in case you haven't noticed.
    Regards,
    Bruckner
  7. Sepp
    Sepp New Member
    A design issue peculier to the VFR is the use of low-friction aluminium/ceramic composite cylinder sleeves that have no top flange. Traditional cylinder bore bar and hone tools may not work correctly on this material. One would have to be careful to engage the right cylinder boring technician acquainted with this potential issue. I'd bet your average small block Chevy engine builder would screw this up.
  8. Spike
    Spike New Member
    Unless of course you can do it yourself.....
    then you just have the price of the kit
    I wouldn't do it, but then hey, to each their own
  9. Spike
    Spike New Member
    just to run with it...
    if you picked up a crashed, with good motor ST, and a VFR with motor problems, you could do away with the financial issues
    it is so tight in there now, I can't imagine it fitting, but I have been wrong before, and people have been known to modify a frame to their purposes...
    without looking at a dyno chart, I would guess you would want to work on the tune of the ST motor, to make it more "sporty" than its design; but hey, if you have the talent and determination to deal with the other issues, I would guess you could deal with that:smile:
  10. Sepp
    Sepp New Member
    Huh?
    ...and if I could harness anti-matter drive I could fly to Uranus in a week!
    Many things are hypothetically possible - it's the real world engineering problems that put your daydreaming in the butt can.:attention:
  11. Saint_Craig
    Saint_Craig New Member
    The real issue is if you had a donor bike could you drop a Gen 5 motor into a Gen 6 frame. :)
  12. jev.
    jev. over there
    Ahhhh... The million dollar question. Someone with more money than me should try it.
  13. Saint_Craig
    Someone with more money and time than I have should try this and let us know how it goes.
  14. oss
    oss New Member
    Temple Tx.
    Time is better spent riding, or figuring out new ways to confuse my boss.(the riding) is a better cause. I don't have to try too hard on the boss.
  15. mello dude
    Romania
    I'd rather take a gen 6 frame and adapt it to a gen 5 bike.
    - I looked into the big bore kit project and the total bill with a competent engine builder was almost $4000. That would be cool but the bike is only worth about $5500. (I have way too much dough in mine already)
    If you jumped out an bought an RC51 you would have more capability than you could ever trick out a VFR for at less bucks.
    MD
