I want to test my Engine.....VFR 750 FV
Discussion in '3rd & 4th Generation 1990-1997' started by triops, Nov 30, 2014.
  1. triops
    triops New Member
    My bike was stolen and used as a getaway vehicle in a robbery. To steal it the steering lock and ignition was smashed the key wont work it
    I have taken the fairings off and the clocks
    I have removed the 5 wire ignition switch and will buy a replacement
    Question
    Will I be able to test the engine by starting it up after fitting a new ignition without redressing the whole bike. Do I have to put the clocks back? on and the indicators, connect up the headlamps I need to know the engine wasn't destroyed or damaged, before I spend more money on it.
    Can I fire it up without the ignition switch working, presumably the idiots that knicked it managed to hot wire it somehow...
    thanks
  2. skimad4x4
    France
    French Alps & London
    Hi Triops
    To save you the hassle of wading through a thread which the search feature on here managed to turn up in a few seconds - it seems that after a long and somewhat acrimonious thread loosely about the same question - it seems that provided everything else is suitably connected up - then the bike should start. But obviously don't forget things like the kill switch, bike in neutral...
    Hope that helps
    SkiMad
  3. triops
    triops New Member
    Thanks for the advice much appreciated , shame about the sarcasm...... someone once told me it was the lowest form of wit....
  4. richierex
    richierex New Member
    you should read the other thread before complaining:sorrow:
  5. triops
    triops New Member
    Yes that worked fine, unfortunately petrol poured out from under tank onto floor, will check out... pipe or stuck float bowl I suspect.
  6. NormK
    NormK New Member
    Ok so why did fuel pour out from under the tank, how long ago was this bike stolen,why would the floats get stuck all of a sudden, has it been parked up for some years, was the bike crashed or has it been laid down? Things like this just don't happen because the bike was stolen. Pull the tank and give us a bit more to go on
