huge earth cluster.
Discussion in 'General VFR Discussions' started by juliesguy, Jul 29, 2012.
  1. juliesguy
    juliesguy New Member
    Wickford, Essex, United Kingdom
    Hi all.
    The stupid orange block that's full of all the earths......
    I've read on here.....I.think.....that some people bundle them together, solder and wrap them all together.
    My question is this:-
    All the earths seem to be in separate slots in the orange connector so is it ok to securely put them all together?
    I went to a store near where I live and noticed they do a metal earthing block with 12 screw connections. Would it be ok to take all the earths from the orange connector and connect them all to this metal earth block and then bolt the block to the frame?
    Any help or comments would be appreciated.
    Paul
  2. djd
    djd New Member
    Translated for Americans... earths = grounds :smile:
  3. tinkerinWstuff
    Yes, that would be a preferred fix to soldering them all together IMO.
  4. coucours grad
    coucours grad New Member
    Covington GA
    Yes. Just make sure you get a good solid connection to both the frame and all wire ends.
  5. tinkerinWstuff
    I plan to do the same modification to mine. I have a custom built wire harness that relocated my ECU. This winter I planned to redo the custom harness and will do a more reliable fix to the orange ground buss.
  6. Ghost_Rider
    Ghost_Rider Active Member
    LA & Utah
    A huge earth cluster is heading towards earth? Heavens to betsy, what should we do??? Somebody, anybody turn on the bat signal!
