HP ratings from a dyno ?
Discussion in 'General VFR Discussions' started by JWB-VFR, Feb 14, 2009.
  1. JWB-VFR
    JWB-VFR New Member
    For those of you that have put your VFR on a dyno, what kind of HP ratings have you gotten? What year and what mods go along with those ratings?
  2. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
  3. hondajt
    hondajt New Member
    springboro, oh 45066
    yup. I tell people its 100hp and no one believes me. Its pretty damn close. For someone with a Power Commander, I would say 100hp is realistic.
    Anyways, Anyone got a torque curve?
  4. rc24rc51
    rc24rc51 New Member
    Liberty SC
    1986 VFR 750 K&N filter modded airbox, stage 2 jet kit w/ stage 1 needles, Yosh 4into 1 slip on with competetion baffle 90 RWHP.
  5. NorcalBoy
    This subject should be more controversial than any oil, pciii map or generation thread. One of the many things concerning motorcycle tuning that is talked about by many and understood by few.
    Copied without permission from Factory Pro:
    Problem:
    Today, about 75% of the entire world's hp values are a mess of dynojet "hp", dynojet clone's rough approximations of dynojet horsepower , some brake dyno mfgr's "dynojet channel" that's " 10% of a dj number" , some dynos that out exaggerate the dj numbers and imply that they know what the transmission hp and crank hp is, and even other dynos with the most expensive brochure that read whatever the user wants them to read, True, Real, SF and DJ..... (sigh...)
    All because some guy thought that a 1985 prerelease version V Max made 145 crank hp according to the marketing dept. and he couldn't have his "new" inertia dyno read 90 hp on a stock dealership V-Max. Well, he WAS right at 85-90, but he made it read 120 to sell more people on his dynos. And that's where the chassis dyno hp mess started.
    Simple Solution:
    True HP.
    Every dyno company can all do it.
    DEF:
    Corrected True HP is the:
    Actual power under Steady State or Sweep with CORRECT inertial mass value at 20 f/ps
    delivered to the drive roller of a chassis dyno
    to which is ONLY added the dyne coast down parasitics and then
    corrected to existing atmospheric test conditions.
    Factory Pro has confidentially refused to exaggerate measured and corrected horsepower figures to sell more dynos.
    Since Factory Pro hasn't rescaled horsepower for the last 20 year and our software reads the same files the same from the very first EC997 dyne system.
    Some Dynamometer companies add to measured rear wheel power readings a factor that is based on ESTIMATED rear wheel power losses (under what power conditions? 125cc? 1200cc? under coasting conditions? with a 3.00x17 bias ply tire? a 190x17 radial tire? New heavy radial tire vs. worn old, light, stock bias ply tire? Who knows?)
    In short, there is NO meaningful "average" tire to get a correct rear tire power transmission loss measurement for all bikes - so obviously, unless they actually measure the power lost in the rear tire, under driven load conditions, NO dyno company should BE ADDING incorrect power figures into the measured power. It's simply wrong.
    The fact that they add varying amounts of power to the actual, "true" amount of power delivered and measured to the surface of the drive roller creates a situation that makes it an onerous task to compare power figures from different brands of dynamometer systems.
    On simple inertial dynamometers, some (most, actually, all that I know of in the MC market) companies use an average for the inertial mass value of the engine, transmission, rear wheel, sprocket and chain on every bike - as if a YZ125 has the same rear wheel or internal rotating mass as a 1340cc Harley Davidson. Needless to say, if the software thinks that the YZ125 had a HD rear wheel on it, it would look like the 125 makes more HP at the rear wheel than it does at the crankshaft. It's simply wrong.
    And - that's why you hear of 125cc Karts that make 43 hp at the rear wheels!!!!!
    It's expensive to measure frictional losses in the engine and drivetrain, requiring the dyno to be able to drive the vehicle with engine off. Add the cost of a 50 electric motor, controlled power supply, etc. It's just not likely that $20,000 dyno will be equipped with that equipment.
    It is also common for dynamometer companies to add to the power readings by adding transmission and primary gear/chain losses back into the measured power readings. Some companies make a concerted effort try to measure frictional losses and, optionally, add the power to the measured readings. Other companies - some that would surprise you - say that it's not important and give a blanket, single factor for frictional losses in every engine. That includes some $25,000-$35,000 dynes.
    Some simply say that there is a meaningful "average" for every motorcycle,(2 stroke, 4 stroke, 1 cylinder/1 transmission, 4 cylinder/1 transmission) and apply it to every bike and that it is not a significant difference.
    Blanket estimates of "average" losses and corrections are, quite simply, incorrect. At the upper levels of the industry, (we are talking about $150,000 - $500,000 AC or DC 4 quadrant dynamometers) it is not tolerated - shouldn't be - and needn't be.
    There is a dyno company that actually has different versions of software that displays their own identical data files as different amounts of power depending on whether you use the DOS version or the Windows version of their software!!
    True Rear Wheel Horsepower (tm) is Factory Pro's standard of measuring the power that is actually delivered to the rear wheel. It is honest, true, fair and duplicable. It is the ONLY standard that can be duplicated by the entire industry - regardless of the dyno manufacturer.
    Following is a reference table so that, if you are used to rather inflated HP figures, you can see what your vehicle would generally make on the True HP Scale.
    Chassis dyne HP
    What is it? What to call it?
    EC997 = "True HP"
    Dynojet = "DJHP"
    It's not really proper to call "djhp" "rwhp", as neither the EC997, dynojet, Fuchs, Superflow or Land and Sea will necessarily produce the same numbers as a dj dyno, except by luck - and the whole idea of True HP is that EVERY dyno manufacturer HAS the capability to provide those numbers!
    The Superflow chassis dynes, the EC997's, Land and Sea and Mustangs are all capable of measuring power in steady state mode and producing the same numbers - they can all measure: torque x rpm / 5252 = horsepower
    We've not diddled with physics!
    The only factor that is added to the measured reading, in True HP Mode, is the additional energy (dyne parasitics) required to spin the dyno roller to whatever speed the roller is turning at - logical, proper and required for any measuring instrument,
    torque x rpm / 5252 = horsepower parasitic power = True HP
    We've not diddled with physics and joined a power "puff" derby.
    Whether they provide a number that is comparable to other dynes (like Factory Pro did), or not, is completely up to the manufacturer - some like to squirrel away their "puff factors" and some actually "lost" their source code and made up new ones that were 2% higher than the old DOS ones.
    Chassis dyne HP - Intertia
    What can inflate HP readings on an inertia dyno, but not really make more engine power in the real world?
    A few things can affect HP when using inertia dynos (not a dyne in Steady State Mode) to measure power (what else would you do??:):
    Changing to a light, worn stock rear tire will improve power output on an inertia dyno, but, not improve real world top speed.
    A heavier (brand new race) tire that replaced the above, light, worn tire, will decrease measured power on an inertia dyno, but not decrease real world top speed.
    Lighter wheels are a good thing!
    Better acc. in lower gears, esp. 1st and 2nd (accelerating less inertial mass!).
    Better suspension is possible, too!
    Flicks from side to side easier and hence, quicker in the "esses".
    Riding hard on worn, light tires is foolish.
    Problems with Inertia dyno test procedure and fuel injected vehicles:
    A Sweep Test (hold throttle wide open and sweep from low rpm to high rpm) will often trigger the ACC. FUEL Map, along with the Main FUEL Map, causing the dyno operator to to lean out the main fuel map to compensate for the additional fuel the ACC. FUEL Map delivers. Of course, in the real world, upper gears, the acceleration rate of the engine is much slower than what they tested, doesn't trigger the ACC FUEL Map, and the bike ends up a lot leaner in reality in top gear.
    It's not that common of a problem, since most people never ride that fast for that long to cause engine damage - but, the manufacturers will find out soon enough about that.
    Work around:
    Tune full throttle fueling in real world usage at dragstrip (to best trap speed) or in Steady State Mode on different dyno.
    Chassis dyne HP
    How can a bike with 132 djhp race and lead with bikes with 141 djhp at Daytona?
    You can optimize tuning for a dj dyno and make big numbers - and you can tune the bike to make best power under load on an EC997 and blow off the big dj dyno numbers - That's what that happened at Daytona a couple of years ago...
    132 djhp Jimmy Moore gsxr750 (115-116 True HP) lead Daytona CCS over 141djhp Team Suzuki's gsxr??? and Zlock Racing's ZX9 -
    How? It's impossible to spot competitors 8 real hp and lead the last few laps until the drafting battle at the line on the last lap!
    The answer is obvious (no - Jimmy's bike was legal - we didn't need to limit the power on it.... It was an end of the year experiment that went awry....)
    The answer is obvious (read above rantings :) and is just another example of non-real world power figures.
    Can a tuner cheat and make an EC997 read higher?
    The only way that could happen is in a Sweep Test - Sweep Tests are the least reliable of all tests. Period. Ours or others. There is NO question about that.
    Since the Rotating Mass is a variable in a Sweep Test (but NOT a Steady State Test! - where it's not a factor), the actual inertia factor entered affects the final HP figure - - Tell the software that the vehicle has a lot of rotating mass to accelerate, and the HP number increases. (torque, rpm, acc. rate and mass are the factors) - just like dj dyno ignoring the difference in mass of all bikes -
    So - True HP, again -
    Steady State Test - No acceleration, mass makes no difference, anymore. Torque, RPM and dyne parasitics. Period. True.
    Can you make a Steady State Test (normal EC997 mode) read higher?
    I can squeak, maybe, 1/2 to 1 HP extra out of an rpm point, at the most. I was curious (big surprise??) and I tried and tried - 1/2 to 1 True HP. That's about it. And that's pretty hard and you have to consciously try hard to do it - and you have to know how to do it -
    The software will NOT take data unless speed and load are completely stable - eliminating cheating (the accuracy is hard coded into the program, so it can't be diddled with!)
    As far as other dynos - and being able to make "flash readings" - that's now, ancient history on most newer dynes. Our dynes have always factored a base inertial mass factor to prevent "overloading" and resulting high hp "flash" readings - even in the Steady State Test.
    I think that that's more possible in older manual controlled systems that happen to be water brake type engine dynos, but, I can't really talk much about them because I do not have recent firsthand experience.
    As far as atmospheric conditions making a 10% difference? Unless you really(!!!) mess with the barometric pressure (and you can look at every atmospheric factor on every test report sheet - it's hard coded to display - not an "option" to display, it is simply, absolutely impossible to do without obvious evidence.
    Some dynamometers will actually display "actual HP" and not specify that it is "uncorrected" to standard air ("SAE Corrected", for example) - A STD HP shouldn't ever be given to a customer - The customer probably doesn't know that "actual" means "uncorrected" and that the results can't be compared to anybody else's dyno chart - I was just reading some UK dyno operator explaining on a cbr600rr forum that "STD" hp was some sort of recognized "standard"... (April, 2006). It's not a standard hp number - it's the actual amount of power the bike made THAT day with that temp, baro pressure and humidity. You can't compare it with any other day and different atmospheric conditions. Period. It's a pretty useless chart for comparison purposes. The only time anybody gives an "STD" hp chart is if he's trying to make the power look bigger than another test with different atmospheric conditions.
    I saw a recent South Bay (San Francisco south bay) chart reading "Actual HP" instead of "SAE Corrected" HP - The dynojet "tuning center" had just installed an undercut transmission on a gsxr1000 and had somehow lost 10-15 djhp - They gave the customer a chart displaying "Actual HP" because it was 3-4 djhp higher than "SAE Corrected" - to try to hide some assembly error - They denied all responsibility......... They should have just figured it out and I never would have had their customer at my door telling me the story -
    The moral? Sometimes the cheapest isn't the best deal - or an honest deal either -
    Are final tuning optimal dyno settings different on an Inertia dyno vs. an EC997
    For many reasons, final tune settings are different - and, since the EC997 does Sweep and Steady State horsepower testing, we have a choice of tests - from a dj style Sweep Test to Steady State.
    Having a choice of those types of tests to do - and having been, firsthand, involved in all sorts of racing - AFM, AMA (250 GP #1,#2,#3,#4), WERA, CCS, Formula USA (750 National Champ and 6 USA Track records!) road racing, drag racing, MX, Speedway, dirttrack, scooter - we have had the opportunity to verify the results of different types of tests and their relevance to the real world operation -
    Without a doubt - the Steady State test Mode is the most consistently superior method of tuning - anybody who has the capability to do it will echo that sentiment - it's only an arguable point with those who can't do it properly.
    One of the reasons why the EC997 provide settings that work better in the real world is that combustion chamber temperatures are more in line with the actual operating temperatures that the engine - Tests done by Champion Spark Plugs at 4&6 Cycle, Chicago area, provided information that combustion chamber / spark plug temps, on a a common inertia dyne were 300f to 400f LOWER than the real world and the EC997 Steady State Test Mode - Nobody should ignore that - that means ignition timing AND fuel are incorrect when set at sub normal temps - too rich and too advanced is not un common error. (unless you are tuning FI - then it can be either too lean or rich)
    On a TZ250? A dj dyno indicated that 3.1mm btdc was optimal ignition timing for best power - and the EC997 indicated 2.6mm btdc - if you knew gp bikes (or even rd350's like me!) that's a HUGE difference!
    How much different? About 6 to 7 hp improvement on the EC997 at 2.6mm - and the bike, now, "ripped" on the track instead of droning in sorry misery - it lost a bunch of power on the dj dyno, but, who cared anymore, the EC997 said that the bike was better and the track performance verified it. The only dissenting opinion was the inertia dyne test results.
    Given an open mind, desire and equipment, one could make up their own mind -
    As for me? I've been here and I've been there - And I like "here" a LOT better!
    If I had to resort to sweep tests, only, I'd quit this line of work (boy - would some people be happy!)
    Final statement - "It's not important which dyno you use - it's only the amount of power improvement that's important." has never been said by a qualified tuner who has the ability to use modern designed dyno systems and verify results on the track.
    Never.
    "True HP" vs. "False HP"
    "True HP" is a term that signified that the rear wheel horsepower figure was derived from the actual power delivered to the drive roller - nothing added (except normal dyne system parasitic drag).
    If some other dynamometer company provides HP figures that will conform to that, they can use the term "True HP". If they don't, then they can't.
    Truth in advertising.
    If they did, then their dyne systems would at least read the same as another "True HP" dyne system - eliminating a bit more confusion in the industry. (but what would make the internet boring).
    Superflow has agreed in principle, so has Mustang and Land and Sea.
    Does altitude make any difference at all in HP?
    The engine couldn't give 2 hoots at what altitude it is tested at - it only cares what the air pressure, temp and humidity is.
    Sea level at 28.02 inches baro is exactly the same as 4000ft/1000 meters at 28.02 inches, as far as the engine is concerned -
    When we test at 5000 ft, we get virtually exactly the same power (corrected to atmos. conditions, of course) as we do at sea level - It's just about 24%-25% less on the track and on the EC997 dyno!
    I am confused (sometimes, easy to do - but not this time :) why some dyno manufacturer's insist on putting altitude on their charts and having the dyno operator swear that it's a factor....... Might as well swear that there's some Merlin the Magician reason as to why one should test in 4th gear!!!
    Crank HP vs. True Rear Wheel HP
    That's a tough one - and LONG....
    The short?
    Take crank HP, subtract 14.6% (please don't email me and ask - I won't answer - search SAE and old Yamaha), take that, and subtract around 10% to 15% and you'll get about True HP at rear wheel.
    The actual formula contains a curve for power loss through gears and there SHOULD be another curve for power lost in a tire (it's the majority of loss on a motorcycle....
    Remember, too - that you are only likely to get a crank number from the manufacturer and that's probably a "good" one that the marketing department is providing... (sound of blowing up a marketing and sales balloon? :) That's not everybody - but it has happened - leaving names out! :)
    When someone gets engineering data from engineering...... give me a call - :)
  6. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    my 86 500 made 27.9hp 15.0ftpq with no mufflers
  7. VifferDude
    VifferDude New Member
    Sydney Australia
    I just read Norcals post, and now I have a headache
  8. eddie cap
    eddie cap New Member
    Valley Forge, Pa
    To all that have read this thread and to those that will; First off, I am not a Dyno expert
    but like to think that I am pretty good at making what the dyno is supposed to read . But I can explain and document that at another time. Anyway interesting question brought up by JWB-VFR and very good input from NCB. After reading what NCB had to say, I suppose one question that I
    would like to ask, I think most of the folks that ride and especially those that wrench on
    their bikes are always wondering ;is my bike running up to par,am I just getting used to
    its power or maybe this bike isnt running up to speed. Call me crazy but this actually
    goes through my mind just about every time I ride. So now we have an expert in our
    midst ( NCB ) and what I would like to know is, Specifically how does one go about getting real world torque and horsepower numbers. It seems that the majority of bike
    shops wealthy enough to have a dyno,usually have a Dynojet machine,I for one
    dont like to throw my $$ away, and I doubt any of you other want to know Horsepower
    guys do either, so how can we go about getting honest horsepower figures. I appreciate
    your formulas,but how do we find shops with Factory Pro equipment or reasonable
    facsimilies that will work on bikes. Personally I would rather put my bike on a trailer and drive some to get an honest evaluation.NCB, from what you said and I have no reason to disbelieve you ,it seems the variation from all these other pieces of equipment multiplied by operator variable lead to some down right fictional HP/ torque readings.
    So help us wannaby knowledgable VFR brethren out. And please no more formulas! eddie
  9. NorcalBoy
    Hi Eddie, I'm no expert, just a student of some people who are very talented and have demonstrated ability when it comes to engine building, dyno tuning and true hp numbers.
    There are a couple Factory Pro EC997 dyno tuning centers in PA:
    Childs, PA MJ Technologies 570-282-2836
    Tarentum, PA Gatto Cycle 724-224-0500 Linky: Gatto Cycle Shop: The best in Western PA
    I suggest that you contact either one, or both, of these companies and talk to them directly about tuning your bike.
    I attend a lot of AMA races and kept seeing and hearing the name Factory Pro in the paddock, so I decided to check them out and see what all the hoopla was about, and I'm glad I did. I am lucky enough to live about 20 minutes from Factory Pro's headquarters. After dealing mainly with Dynojet for the last few maps for my bike, I went down and talked to Factory Pro, all it took was one visit and that was it for Dynojet dynos for me. My old Dynojet guy is really pissed at me right now because I have severed ties with him, found a new engine builder, and chosen to go with Factory Pro directly for my tuning. The proof is in the results. 100 rwhp VFR's aren't stock and who the hell dyno's anything off the friggin' crank? Believe whatever you want, I prefer the truth.
  10. Nitrousva
    Nitrousva New Member
    Richmond
    94.1 rwhp, Two Bros full exhaust with insulating wrap, K&N air filter with entire air box wrapped with insulation, jetting that I worked on for a season. I was hoping for 100 hp, perhaps i should have it dyno'ed in the winter next time, LOL.
    Robert
  11. Somefun
    Somefun New Member
    Orange, CT.
    I just put my 2005 on a dyno and when we were finished we made 100.6!!! Not bad but I'm looking for the toro super charger kit cuz I'm in the need for MORE SPEED!!!!
