How to lower your 6th gen. (Triangle Flip)
Discussion in 'Mechanics Garage' started by mmcinnis1, May 13, 2008.
  1. mmcinnis1
    mmcinnis1 New Member
    CT
    Do you know where the triangles are? If you do and have a few tools you can do the back in less than an hour. A torque wrench is highly recommended. You will need this tool over and over for this bike.
    Put the bike on the center stand.
    Remove rear tire.
    Put a jack under the swingarm brake assy.
    I bundled up a rag between the jack and brake.
    There is very little weight. You just don't want it to drop down and you can jack it up to the new height easily.
  2. mmcinnis1
    CT
    Remove the three bolts holding the triangle.
  3. mmcinnis1
    CT
    Rotate the triangles as shown in the picture. The stock position is the one on the left with the arrows pointing forward. You want both of them pointing towards the rear and up like the one on the right.
  4. nozzle
    nozzle New Member
    Southern Maryland
    Nice pics and *very* clean bike. thanks!
  5. mmcinnis1
    CT
    Reassemble the triangles and torque the bolts to the correct specs! You should need to jack up the swingarm about 3/4 inch (20mm) to line up the holes correctly.
    Put the tire back on and torque those too.
    I lowered the front 10mm and all was great.
    Will post the procedure for the front when I have time.
    All Done!!
    Steldel likes this.
  6. mmcinnis1
    CT
    Thanks.
    It probably had 150 miles on it at the time. Up to 300 now. :rockon:
  7. powerslave
    powerslave New Member
    winnipeg,manitoba.
    Awesome job,
    Can't wait to see the lowering of the front!!!
    This is a job I have been planning so thanks for postin' up!!!
    P.S.
    Is that candy glory red???
    Excellent colour!!!!
  8. VFRHUMP
    VFRHUMP New Member
    Wisconsin
    How much did this lower the seat height of the bike from stock?
  9. jasonsmith
    jasonsmith Member
    Vancouver, BC
    Nicely done, thanks for the info.
  10. toxicdump
    toxicdump New Member
    Did you take a before and after measurement?
  11. mmcinnis1
    CT
    20 mm rear drop. That's why you have to raise the swingarm up 20 mm or so to realign it.
  12. hank6167
    hank6167 New Member
    Oklahoma
    Great info!
    Question;
    What are the triangle bolt torque specs? And why I'm at it, what are the fork tube, pinch bolt torque specs?
  13. Gazz1958
    Gazz1958 New Member
    Brisane Aust
    Thanks for the posting to lower the rear, as a shorty 20 mm is just what I need and I look forward to the front suspension post. Cheers from OZ
  14. olivino
    olivino New Member
    New York
    Thanks also, I have the same bike and have been wondering how to do this for a while. Funny but the triangles look symmetrical, it's just not intuitive that this would lower the height. Is this a standard way to lower for the VFR, asking because some people buy link lowering kits.
  15. cebuVFR
    cebuVFR Member
    Carson,CA
    Thanks for the info and detailed, quality pictures. Been looking for this solution for a while.
  16. stumpy
    stumpy New Member
    Gazz1958 Did you ever get the front suspension post?
    Regards,
    Stumpy
  17. tgreene5
    tgreene5 New Member
    Portland, OR
    Late question, but I have a 2002 I have been thinking about lowering like this. I'm only 5'5", and they just don't make these for ladies. Anyway, since you have had some riding time on it, can you tell me the pros and cons? Any change in cornering, stopping, starting, high speed cornering (is there any other kind??)
    Would you do it over if you had the choice again?
    Thanks!
    Theresa
    PS - just LOVE that color!!
  18. VifferDude
    VifferDude New Member
    Sydney Australia
    I did it, and the only thing I regret is not lowering the front at the same time. If you do decide to do it get the forks dropped in tripple tree 15mm to match. If you drop just the back and not the front it wont turn into corners as quick.
    I'm 5'7"and had trouble pushing the bike bacwards out of parking spots and balancing it while my girlfriend got on and of etc. Before the lowering I could just touch the ground with the ball of my feet. Now I'm almost flat footed. Gives you a lot more confidence because you no longer worry about dropping the bike.
    The only cornering issues is that there is less ground clearance so the peg feelers hit the ground sooner. If you corner that hard and you're that concerend about it you can put shorter peg feelers in (of a CBR perhaps?) Just don't corner to hard if you have panniers on!
    Notice the guy in the above picture has removed his peg feelers
  19. dakcan
    dakcan New Member
    Sea to Sky
    lowring VFR
    any news on how to lower the front yet, or any tips
    thanks
  20. G-BABY
    G-BABY New Member
    Reykjavik
    do you have any problems with the side stand after you lowered it ?????
