How much fuel pressure/flow do I need with the Gen 5?
Discussion in '5th Generation 1998-2001' started by makenzie71, Dec 7, 2014.
  1. makenzie71
    makenzie71 New Member
    My mini buggy just isn't working out with the VFR tnak and pump. Sure, having a fuel gauge is awesome, but I'm going to have to ditch the thing and run an inline pump.
    There's a slew of 60psi/110lph pumps on eBay for $50~60. Would that be adequate for the VFR800?
  2. TNRabbit
    TNRabbit New Member
    Woodford, VA
    I believe stock fuel pressure is 36 psi.
  3. Terry Smith
    Yes quite right, 36psi or 250kPa. Fuel flow is stated at 150mL per 10 sec, which is 54L/hr. The higher flow rate and pressure might be too much for the fuel pressure regulator to handle?
