How do I remove the side fairings on the VFR 800 2002?
Discussion in 'Mechanics Garage' started by vfrbananas, Aug 26, 2015.
  1. vfrbananas
    vfrbananas New Member
    The side fairings on the 2002 VFR800 seem to be still attached to the front fairings after I loosened all the bolts.
    Pulling it slightly away from the body and using a flashlight it looks like there are clips on the inside that hold the two together.
    Can someone give ma a hint on how I am supposed to remove the side ones?
  2. duccmann
    Chin insert, 4 bolts there. 4 bolts holding the fairing on, 2 clips holding both together on the underside, inside behind the front wheel half way up I think theres 3 clips...
    If there stock, I usually use my thumb nail to bush the center tab in, then pinch and pull out
    (sounded weird)
    Hope this helps.
    Left fairing has 1 more bolt right behind the kickstand
  3. GigemVFR
    GigemVFR New Member
    TEXAS
  4. duccmann
    There ya go....when I bought my bike it was March and rainy so I just went out to the garage and removed all the fairings just so I knew how to.
  5. vfrbananas
    Thanks guys, the instructions were excellent.
