How can I remove the stubborn plastic bolts that hold the speedo cover on?
Discussion in 'Mechanics Garage' started by greenyogi8, May 26, 2010.
  1. greenyogi8
    greenyogi8 New Member
    Westerly, RI
    Hello VFR fans,
    I've got an '86 VFR750F and the plastic spedometer 'glass' is cracked, so I ordered a new part. The darn plastic bolts that hold the cover 'glass' on are stuck and won't budge. I can tell that the socket just wants to spin on the bolthead, so I dn't want to snap them off and then have to drill 'em out. Any suggestions for loosening those things up? I'd try something like WD-40, but I'm afraid that might cause some melting and make matters worse. Can anyone shed any light on this for me?
    Thanks, greenyogi8
  2. clublights
    clublights New Member
    Denver Colorado
    Did you ever figure this out ? I've thought about replacing my cracked glass too ..................
  3. greenyogi8
    Westerly, RI
    No other responses.
    Come on, all you VFR FANS! Any suggestions appreciated.
    Help me make my '86 look proper. The cracked lens cover just doesn't match the low 27K miles!
  4. tinkerinWstuff
    special tool for that
  5. betarace
    betarace New Member
    Middleburg, VA
    are you sure they arent ornamental? on my G3 these "bolts" are just molded into the plastic, the real bolts that hold the speedo in are on the back side of the dash.... just thinking
  6. tinkerinWstuff
    I think you're probably right but I still like the jackhammer idea
  7. greenyogi8
    Westerly, RI
    Ahhh...never thought of that. I'll check tonight and post my findings.
    Thanks, betarace!!
