Too bad gas prices are falling cause I just came up with the shiznit. Home made fuel booster. 2 parts Vaseline 1 part isopropyl Alcohol..... Add to a tank of Regular gas and voila ... Rocket fuel....OK, well not rocket fuel but close. You can get 5-7 extra HP depending on year/engine size and the best part was a pleasent side effect. That's right! Better Gas Milage..... 56MPG for me up from 38MPG. Part=2.5OZ :bs::bs::bs:
i hate to be a killjoy, but you really shouldn't put alcohol in your bike . read your owners manual. sorry
That's a great idea bitterpill. I'm going a little farther by adding 2 parts Slick 50 and 1 part kerosene to the mix. That should give even more hp and mileage.
Hm....interesting. If you don't want to use isopropyl alcohol, might be able to substitute xylene or toluene. Those are already consitutents of gasoline at up to about 40% by weight. Some might say acetone but that might be more risky. How about mineral oil in place of vaseline do you think that would work? Some people use automatic transmission fluid, it's supposed to be a great cleaner and lubricant in the fuel system. I have a little special blend I usually make up for the cages. ..haven't tried it in the viffer....
