High Beam Problem
Discussion in 'Mechanics Garage' started by mightyquinn, Nov 13, 2006.
  1. mightyquinn
    mightyquinn New Member
    I have a 96 VFR and I'm having a small problem with my high beams. When I switch to the high beams there's a delay before the high beams go on. So I have no headlights for a second or two until the high beams come on. This doesn't happen all the time, maybe about ever five times I switch on the high beams. So the way I can reproduce the problem is I switch back and forth between the high and low beams and on the fifth time I hit the switch I get a delay.
    I'm guessing there's a loose connection somewhere, but I haven't found anything yet. Has anyone experienced something like this? Any ideas?
    Thanks...
  2. tbones86
    tbones86 New Member
    N/W Central Wisconsin
    Could be dirty or loose contacts in the switch itself, I would almost bet that it is vs. a loose wire connection. That just based on you descripiton; take the switch apart & clean w/ a good quality electrical cleaner(something that doesn't leave residue). A good rule of thumb when diagnosising an electrical problem is to start @ one end & work your way to the other; if you start in the middle your bound to be pulling your hair out w/i an hour. Start @ the switch & work your way to the headlamp; or if you want to spend more time start @ the headlight & work your way to the switch. I've beat my head against the wall for years coming up with that theory, its just to easy to get confused in the middle.
  3. Rev
    Rev New Member
    Olympia,WA
    Might be a bad relay too
