Hi-Level Link Pipe
Discussion in '5th Generation 1998-2001' started by Mohawk, Mar 12, 2014.
  1. Mohawk
    Mohawk New Member
    Bristol
    Well I finally got my replacement link pipe copied from my home brewed one. The pics tell the story :)
    Old & New
    Old fitted for pic of top alignment
    New fitted
    Full view
    Panel alignment even better than the old
    Pipe was made by NRP in the UK for those that may be interested.
    Enjoy.
  2. Motographer
    Motographer New Member
    Nashville, TN
    Dimensions please! I'm not in the UK, but I badly need a link pipe that actually fits, unlike my current one.
    Sent from my Nexus 5 using Tapatalk
  3. tinkerinWstuff
    That looks excellent
  4. Mohawk
    Mohawk New Member
    Bristol
    Well I would send dimensions, but its difficult, hence I made the original & sent that as a template for the exhaust guys to copy. The shape makes it really difficult to measure. Both bends are 45degrees, the bottom bend is at 45degrees to the fore/after line of the bike, so if looked on from above sitting on bike, the bottom bend points to between 10-!-11 o'clock, with the top bend pointing at 6 o'clock toward rear of bike.
    I had to cut 6mm off the end at the top to get the can to match with the rear bracket I had added before.
    Hope that helps.
  5. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    Very nice but not as nice as that rear wheel ya got there!!! Is that CF??
  6. Motographer
    Nashville, TN
    Yeah, the compound bend at the header is what messes my Delkevic up, they got it totally wrong. Do you still have the centerstand fitted?
  7. Mohawk
    Mohawk New Member
    Bristol
    Yep CF wheels both ends.
    The main stand is still there, well its in the pics ;)
  8. patch10
    patch10 New Member
    bere alston
    very nice you are localish to me if you see a rothmans vfr about give us a wave
  9. silverbullet132
    silverbullet132 New Member
    No risk of melting the plastic? Was thinking about doing the same with mine.
  10. Mohawk
    Mohawk New Member
    Bristol
    Well my Ti can is very good at keeping the heat back. Last summer in 32c heat I could touch the can with bare hand after a spirited run. Thousands have done this & back in its day many companies made a hi level end can kit. So IMO no heat problem.
  11. silverbullet132
    Ah, my can is not TI though so guess I can't do this (vance and hines SS2R)
  12. Mohawk
    Mohawk New Member
    Bristol
    Most of the cans used previously were carbon/alloy or SS. So any can can be used.
  13. silverbullet132
    100% sure there will be no issue? My can has got pretty hot on longer rides.
    Is it possible to just ceramic coat the inside of the can? Worth doing?
  14. Markvfr800
    Markvfr800 New Member
    lovely bike well done, you could start a little business with that original piece!
  15. Mohawk
    Mohawk New Member
    Bristol
    New heat shield :)
