Anyone have experience with this product? (see link) http://www.clarysports.com/main.cfm?p=12&l=en&item_ID=415&categorie_ID=15 I'm having a hell of a time installing this thing...it doesn't seem to fit **(See my post in '1998-2001' for more detail) Anyone?...Bueller? RF
Had the same one on my '98. Need to remove the exhaust can and rear wheel. Side bolts are no brainers but the top mounts need to be drilled or reamed out larger. Oddly, some swingarms only have one hole in the top flange but there are two top mounts on the hugger; both are necessary to properly center the fender part over the wheel. I used a Dremel tool to ream the top mount holes to the proper (9mm I think) diameter for the rubber nut inserts.
