help
Discussion in '1st & 2nd Generation 1983-1989' started by afroken, Nov 22, 2010.
  1. afroken
    afroken New Member
    derbyshire/england
    i have a 83/84 vf 500f2e during the rebuild i saw a crack on the carb .will any of the later vfrs carbs fit this bike . thanks
  2. commrad
    commrad New Member
    Red Hill, GA
    short answer, yes but later models are smaller bore and have different jetting..
    I assume the UK version would be the same
  3. afroken
    afroken New Member
    derbyshire/england
    yes there the same. thanks 4 the reply
  4. commrad
    commrad New Member
    Red Hill, GA
    if you need some help getting parts across the pond feel free to hit me up, I need some things from the F2 models yall have over there :biggrin:
  5. commrad
    commrad New Member
    Red Hill, GA
    btw can you post a pic of the crack? epoxy might take care of it if it's in the right place.
  6. afroken
    afroken New Member
    derbyshire/england
    what u after 4 the f2 i got some spears 4 a 86
  7. commrad
    commrad New Member
    Red Hill, GA
    mainly the "yellow" stuff, gauges (clocks I believe they are called over there) and handle bar controls.
    I can buy the controls here new here in the states at bike bandit. do you know of anywhere there I might could order the ones with yellow print?
  8. afroken
    afroken New Member
    derbyshire/england
    ill keep an eye out 4 u
  9. afroken
    afroken New Member
    derbyshire/england
    do u know if i can swap my fuse box (83/84 glass type)4 a new type (spade 86) on a vf 500
