Help
Discussion in 'Mechanics Garage' started by jsalty, Feb 7, 2009.
  1. jsalty
    jsalty New Member
    Inverness, FL
    is the gap on the left side of the front wheel between the bearing spacer and the fork tube normal?
  2. jev.
    jev. over there
    Yes, the spacer and axle are actually tight against each other, it just looks like there is space in between but the axle is butted up against the spacer.
  3. jsalty
    jsalty New Member
    Inverness, FL
    I just put this thing back together after having new tires put on and new bearings pressed in by the Honda dealer and upon reassembly i noticed a space 1/4 or so between the FORK TUBE and the SPACER on the right side, the Axel does contact the spacer.
    the picture does show the gap between the fork tube and the spacer and allows you to see the axle (its greenish).
    so is this gab a concern? (spacer to fork tube?)
  4. jev.
    jev. over there
    Everything looks normal in the picture. It looks just like mine.
  5. RWB25
    RWB25 New Member
    North Bay, Ontario
    Yup, same here. All looks normal.
  6. jsalty
    jsalty New Member
    Inverness, FL
    thanks guys it looks the same, must be the axle collar .. i feel better seeing the other pictures..
  7. deepdish
    deepdish Banned
    I think its like that spacer against metal, but how about hose perky b cups?? :thumbsup:yum yumm...ok b- but whos judging..:eek: its wierd how they line up like that though and it does look strange like wtf this side out more then that side huh????:cool:
  8. KC-10 FE
    KC-10 FE New Member
    B cups my ass. If those things are B, I'm Chinese.
    Once again J, Thank You for the awesome avatar. :thumbsup:
    KC-10 FE out...
    :plane: :usa2:
  9. Mac
    Mac New Member
    NC High Country
    Don't worry, it only goes back together, one way.
    Mac
