Help with my 86 VFR700????
Discussion in '1st & 2nd Generation 1983-1989' started by dutchwurx, May 4, 2011.
  1. dutchwurx
    dutchwurx New Member
    Knoxville, TN
    Hey Everyone,
    Im in the process of stripping my 86 VFR700 completely to the frame..I have everything off except the kickstand..im trying to get the allen bolt with a big nut off..can anyone clue me in on what comes first..do i need to get the nut off first? if so do you know what size it is?
    Also what do i need to get the swingarm off? Yes i feel stupid but hey im sure im not alone when it comes to a first time teardown on a bike..
    As always thanks so much for your help..
    Dutch
  2. dutchwurx
    Knoxville, TN
    OK i know now its a lock nut on the lower engine bolt..does anyone know what size it is?? i dont have a socket big enough so if i knew the size id just buy one...thanks
  3. crustyrider
    crustyrider New Member
    North Country, New York
  4. TOE CUTTER
    30mm nut. It's only purpose in life is to hold the kick stand on. The bolt is secured on the other side of the frame with a self locking nut that will come of easily. The bolt on the other hand may put up an epic fight. It is quite large where it meets the frame and is prone to corrosion. Use a good (not worn) allen wrench to attack it and do not damage the bolt unless you are ready to replace it. Hell it may just jump oot for you but my but puckers when I need to tackle one. Good luck.
  5. dutchwurx
    Knoxville, TN
    if im reading it right it says the nut is a 22mm but thats not even close..im thinking more like a 32mm or 34mm???
  6. dutchwurx
    Knoxville, TN
    Thanks Toe..after this bolt im almost done. Any tricks with the swingarm? What size allen wrench do i need for it?
  7. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    I think you will need a 12 and 14mm allen for the two swingarm bolts.
  8. dutchwurx
    Knoxville, TN
    Just a follow up and in case you are removing the bottom engine bolt for the first time..oh yeah its no fun..thanks for the heads up Toe.
    Heres what i did and she rolled out like butta! Heat the frame using Mapp gas and while shes hot give it a good spray of PB Blaster and a few good taps with a steel hammer..be patient and repeat the process as many times til the bolt lets go..being a 6mm allen head its very easy to ruin a bunch of wrenches in the process if you try to force it.
  9. camo
    camo New Member
    The Heartland
    I just went through engine changing myself on my 86 700 last weekend, guess I was busy and didn't see your post then. When you put it back together make sure that you install the long bolt first and then the ones on the upper back next. The engine kind of swings up in place.
  10. dutchwurx
    Knoxville, TN
    Thanks for the heads up! I took it apart just to put back together lol...just wanted to learn the bike.
