Help with aftermarket fairing.
Discussion in '1st & 2nd Generation 1983-1989' started by thor294, Oct 7, 2010.
  1. thor294
    thor294 New Member
    Ringoes, New Jersey, United States
    So, I was about to put this aftermarket fairing back on, and one of the damn brackets came loose and fell off!!!
    the highlighted piece is the piece that is missing off the opposite side.
    thats a picture of the fairing on the bike if that helps.
    Does anyone have any idea what kind of fairing this is... I need this bracket, and I dont think i can make it myself. I can make the spacer, but not the part where the fairing screws into. Thanks everyone!
  2. 02 VFR Rider
    02 VFR Rider New Member
    you should be able to make one yourself, just drill a hole for the fairing to bolt to and use a nut in the back.
    it looks like you have room to reach in there to use a nut.
  3. thor294
    thor294 New Member
    yeah i might just try to bend a straight piece of metal to be like the said bracket then use a nut. hopefully that will work. :p
  4. 02 VFR Rider
    if you can find an allen head bolt in 1/4-20 I can send you a rivnut to put on it, I just dont have any in metric.
    that is the fixed part the fairing nut goes into.
  5. mrvfr
    mrvfr Banned
    looks like its just a carriage bolt going through it. should be a nut on the other side.
    from what i see in the pic anyway
  6. tinkerinWstuff
    you mean this piece?
    ya, I think you're going to have to fabricate something on your own.
  7. tinkerinWstuff
  8. thor294
    thor294 New Member
    I saw that but it looked nothing like mine so I skipped it. I can probably call them, but Im going to try to fab something first. hhaha. thank you =)
    and yes thats the bracket, except mine has a big philips head screw going into the upper front fairing. haha :p
