Help trying to download power commander map for 2001 vfr800 fi please help
Discussion in '5th Generation 1998-2001' started by hollenbeck, Dec 22, 2012.
  1. hollenbeck
    hollenbeck New Member
    easley,sc
    ok guys I have a problem. I bought a 2001 vfr 800 intercepter fi off of a guy that had a power comander 3 usb already installed on it. my problem is that he didnt map it and when i went on powercomander.com and tried to dowload the map it wouldnt let me open it up. my bike is fully stock so if anyone can upload the best map for my bike i would really aprechiate it. and if you can let me know where i can find the cd or download the program that comes with the power comander. any info would help alot.Thank you so much
    also if it wasnt mapped right would it make my take-off slugish or choppy?
  2. OOTV
    OOTV Member
    Everything you need should be on Dynojets website, if not, you may call them or send them an email. I had an issue downloading a map for my PCV and the tech I spoke to just sent me all of the map files they had for my VFR via email.
  3. hollenbeck
    easley,sc
    I just figured out the maps weren't opening cause i didn't have the program,but in your opinion whats the best map for a stock 01 vfr800 that wouldn't make take-off so choppy,thanks
  4. Scubalong
    Use the one that closes to your set up
    Does ur bike come with after market exhaust, o2 eliminator?
  5. hollenbeck
    easley,sc
    no its completely stock,I just looked up an o2 eliminator and am gonna oder one can you tell me what it does and whereto install it?.i've been focused on modifying looks,ive got all parts just haven't put them on parts are:smoke turn signals,zero gravity windscreen,sargent seat,custom levers,and Led kit.
  6. OOTV
    OOTV Member
    As Long said, the one closest to your setup, but if the PCIII is on there why not put it to good use and get it tuned for your bike and get rid of any performance issues. Most Dyno tuners charge around $250.00, at least here in OC, California. I'm sure you can find a tuner near you, I believe DynoJet list Dyno tuners on their website as well. Also not sure if the PO did any air/fuel system maintenance you may want to make sure your air filter is new and/or cleaned an oiled if it's a K&N style filter. Maybe even run some Seafoam in the gas. Sea Foam Sales Company it's available at Autoparts stores and places like Walmart.
  7. OOTV
    OOTV Member
    I should also add that the PAIR valve system should be removed or disabled in order for the Dyno tune to work properly. See here for info...http://vfrworld.com/forums/5th-generation-1998-2001/35929-how-pair-removal-5th-generation.html
    More than likely you'll get a installation instructions when you buy the sensor eliminators from DynoJet, but I'll see if I can find the installation instructions for my PCV, I believe that the 5th and 6th Gen O2 sensors are in the same place. If I can find the instruction sheet I'll scan and post up the image.
    Cheers
  8. hollenbeck
    easley,sc
    awesome i appreciate it,also do you know a decent cheap black slip-on exhaust for 01 vfr800 or do I really need an after market exhaust for the power commander to do its full potential?
  9. OOTV
    OOTV Member
    Personally I don't think you need to buy an aftermarket exhaust to allow the PCIII to provide you with a well running bike, but buying an aftermarket exhaust and not using a PC would, in my opinion, not allow the pipe to maximize it's level of performance. One of the reasons I bought my PCV is because my bike came with Two Bros exhaust system and I was experiencing a lot of backfiring and the typical low speed stumble that has plagued 6th Gens. Putting the PCV on gave me what I needed to cure both issues. Hopefully the attached image is viewable/legible.
    Cheers
  10. hollenbeck
    easley,sc
    ok guys I didnt pay attention,I'm a dumba**,i thought I had a power commander 3 but its actually a 2 does anyone know where i can download program and a map for it,thank you and if anyone has a pc3 usb for sale let me know!!!
  11. CharlesW
    CharlesW New Member
    Ankeny, Iowa
  12. hollenbeck
    easley,sc
    thank u,i talk to him pretty often so hopefully he'll sell if not idk lol
  13. Scubalong
  14. CharlesW
    CharlesW New Member
    Ankeny, Iowa
    No confusion.
    Hollenbeck definitely is interested and posted in the thread "Dynojet Power Commander"
    Addendum.
    Looks like you guys got together.
    Hollenbeck: You won't be disappointed in the PC3 USB.
    Does a great job on my 2004.
  15. hollenbeck
    easley,sc
    can anyone find maps for pc2 on 01 vfr800 please?!!!!!
  16. Scubalong
    Have you talk to Tink? He just bought a pcii and upload some map from the web. It is a bitch but he did it.
  17. Scubalong
    Try send Tink a PM for fast response
  18. hollenbeck
    easley,sc
    idk who tink is lol,I haven't gotten used to vfrworld,idk how to send friend request or anything lol.can u ask him or send link for a decent map and what program to use and how to get it.thanks man I really appreciate it,oh also how to send the map to a pc2
