help no clutch after changing front sprocket
Discussion in '5th Generation 1998-2001' started by revguy, Feb 26, 2012.
  1. revguy
    revguy New Member
    North Bay Ontario
    I just replaced my front sprocket and for some reason my clutch no longer seems to be working ?? I pulled the drive sprocket cover and hydrolic clutch thingy attached to it and reasembled to make sure I put it together properly, but I can change gears without pulling in the clutch lever .
    I checked the resorvoir and there seems to be plenty of fluid, but the clutch lever seems like its not doing anything .
    PLease help with any suggestions.
  2. free4by
    free4by New Member
    sydney aust
    Sounds like the pushrod hasn't located into the slave cylinder (hyrolic clutch thingy ).Just pull the slave back off ,lube it with grease and refit the pushrod into the depression in centre of slave. Check the slave hasn't been damaged . Cheers
  3. Scubalong
    If you open them up and it pop.........might want to flush all the fluid and fill them up and make sure to blitch them until no bubble. There is a thread how to....in here some where.
  4. revguy
    revguy New Member
    North Bay Ontario
    Thanks guys !
    I tried both ideas and its working properly now!
    I really appreciate your help. What a great site !!
