1992 750....left side blinker/running light isnt working checked bulb and fuse??? what else could it be???
Blinker 1. Is the rear blinker working? Yes, check the wiring connector to the front inside the fairing and the bulb socket, bulb may be loose or bulb bad. No, check the blinker connection in the left side rear fairing. Connection or blinker could be bad. Occasionally the signal connection in the handgrip develops corrosion and will need to be disassembled and scotchguard the plate in there and reassemble. Larry
