hello
Discussion in 'Introductions' started by pursey wales uk, Jun 26, 2008.
  1. pursey wales uk
    pursey wales uk New Member
    my tag is pursey wales uk and i have a red 1997vfr 750 that has lost all electrics when the ignnition is swiched on there are no lights on the instrument fasia its as if the batty has been disconncted ihave checked the battery leads and fuses and all appears ok i was riding the bike when this happened can anyone offer any advice please thanks Pursey wales uk
  2. derstuka
    San Diego, CA
    Welcome Pursey Wales! Glad to have another VFR member!
    Sounds like you could have the dreaded bad R/R (Regulator/Rectifier). Have you tested your battery to see what kind of a charge it has? Have you cleaned your battery post connections? Have you inspected your R/R and the connectors going into it to see if they are burned/melted? If your battery was low/dead, trickle charge it and see if the bike lights up. If it does, you will need to test the battery as the bike is running at idle, and up to 5-6k to see if the voltage is increasing, or dropping/staying the same, this will help you figure out if the R/R is bad. We have a bunch of threads on R/R repair/testing if you do a search.
  3. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    Welcome to VFRWorld, pursey wales uk. I agree with stuka, sounds like your r/r took a powder. There are many threads about r/r failures so they should be easy to find. If you need a bit more info, feel free to ask. :smile:
  4. VFRShorty
    VFRShorty New Member
    NW Oregon
    Welcome pursey! Looks like these guys got your info for you, I hope you get it fixed ok! :smile:
  5. drewl
    drewl Insider
    Virginia Beach, Va
    Welcome aboard.
    Just a thought...How old is your bike?
    It may be a dirty connection at the kill switch on the right bar instrument cluster.
    A quick clean with small amount of cleaning oil can make it like new again.
    This cluster gets dirty on older bikes.
