Heated grips
Discussion in '5th Generation 1998-2001' started by fyrmann, Sep 21, 2004.
  1. fyrmann
    fyrmann New Member
    Hey out there, anyone installed heated grips?
    TIA,  Ron
  2. vfracer
    vfracer New Member
    New Jersey
    I have them on my ride.....its not that hard to do...Just takes time.
    I just dont remember which brand.
    LOVE them!...
    Steve
  3. Guest
    Guest Guest
  4. vfracer
    vfracer New Member
    New Jersey
    ;DThat's the one I have also...They work great .
    IT would be tough for me to ride another bike with out them .....
  5. vfour800
    vfour800 New Member
    Athens, GA
    I've got grip heaters from 2wheelinnovations.com. They are the same as the Dual-Stars. Today it was 18F outside. They heated up fast and kept my hands toasty.
    I wired up the fuse and relay one evening. Took about 30 minutes.
    I attached the heaters and switch another afternoon and it took about 1.5 hrs.
    I'm not electrically inclined. Did a lot of web research and found what I needed before attacking the job. Saved me a lot of headaches and time.
    Mark Z
  6. Guest
    Guest Guest
    I installed a set similar to the Dual Stars in late fall and it was great. Paid for themselves with the ride to Lake George NY the last weekend of October.
    I used a relay in the wiring circuit so the switch isn't hot all the time, just when the bike is on.
    Future mod is to eliminate the switch and add a Heat-troller. Fellow rider did this and found there is much more heat to be gained using the heat-troller. There is a lot of loss in the stock switch and resistor that's in the stock kit.
    BKS
    '00 VFR
  7. Guest
    Guest Guest
    I installed a set similar to the Dual Stars and they worked wonders. Also added a set of gel grips while I was at it.
    I added a relay to the wiring to they're hot only when the bike is switched on. Also, fellow rider who installed them ditched the switch and added a heat-troller. A lot more adjustability and more heat if you want it. There is a lot of loss in the stock switch and capacitor (resistor?) that comes with the switch.
    -- BKS
    '00 VFR
