Headlight problem Low beam not working
Discussion in '7th Generation 2010-Present' started by finchdr, Aug 23, 2018.
  1. finchdr
    finchdr New Member
    A couple of weeks ago my low beam stopped working but high beam still good.
    Replaced both bulbs but low beam still not working.
    Dismantled and cleaned both switch blocks but still not working.
    Changed the plugs on the back of the globes and low beam globe works when high beam is on. So definitely not a bulb issue.
    I’m now suspecting headlight relay. I’d appreciate any input on the problem.
    Sent from my iPad using Tapatalk
  2. fink
    fink Member
    Check feeds into the relay. Have you checked the fuses, is everything else working?
  3. finchdr
    finchdr New Member
    Yes, everything else works and fuses are all good. I’ll get the electrical engineer the son over to check out feeds.
  4. finchdr
    finchdr New Member
    All good, bad connection on left hand control, first plug from switch block
    Thumbs, skimad4x4 and fink like this.
  5. fink
    fink Member
    Glad to hear your sorted and thanks for posting back. Not many do.
    finchdr and skimad4x4 like this.
