Header?
Discussion in 'Mechanics Garage' started by SHADOWGERARDI, Jun 29, 2007.
  1. SHADOWGERARDI
    SHADOWGERARDI New Member
    NORTH APOLLO PA
    Has Anyone Built A Header System For A Early 90's Vf? Was Wondering If Getting Rid Of The Cat Would Cause Any Problems? I Almost Have Mine Done And Im Hooking It Into A Yoshi Muffler For A 2002 Cbr 600 F4i. Looks Very Cool Right Now I Just Haft To Smooth Out Some Of The Welds. The Tubes Are 1 And 1/2 Inch
  2. VT Viffer
    VT Viffer New Member
    South Carolina
    1.) A header on these bikes is a very complicated undertaking. I doubt that de-catting it will cause any significant issues, but you may need to re-jet the carburetors to account for the change in the air/fuel ratio.
    2.) How Can Anyone Type In A Way Where Every Word Is Capitalized? Only The First Word And Proper Nouns In A Sentence Should Be Capitalized. Sorry I'm Such A Dick, But I Used To Be A College Newspaper Editor, And Correct Grammar And Sentence Structure Is A Pet Peeve Of Mine.:wink:
  3. SHADOWGERARDI
    NORTH APOLLO PA
    Well Honestly I Did Not Do That, It Must Be A Program In My Computer? And My Header Will Not Include A Cat, Thats What I Was Wondering About, Having A Problem Without One?
  4. rode2rouen
    rode2rouen Guest
    i dIDN'T rEALIZE tHE eARLY '90S vFRS hAD a cATcONVERTER iN tHE eXHAUST.
    rEX
  5. VT Viffer
    South Carolina
    No problem, your posts just look funny.:biggrin:
    I would think that removing the cat (by creating a "test pipe" header) would not be a significant issue. Like I said earlier, You would have to adjust the needles and jets in the carb to accomodate for the much higher exhaust flow.
    I saw one of your other posts with running issues - it seems as if you have already worked on these carbs. I think that a stage 2 jet kit (if available) would work for your header. Also, you need to make sure that the header itself does not have any leaks. This could also cause poor running.
    I de-catted my '94 Honda Civic (intake & header/fullexhaust) with no issues other than it running slightly rich.
  6. SHADOWGERARDI
    NORTH APOLLO PA
    Im Mainly Just Wondering About The Loss Of Back Pressure, Because There Will Be No Cat? As For Leaks, I Have Been Working On This For About 2 Months Taking My Time And My Welds Look Factory Ha Ha , I Have Also Jumped Up 4 More Teeth On The Back For The Loss Of Some Bottom End. Jetting Im Sure You Are Right About, But I Have A Stage 2 Kit Already That I Took Back Off The Bike Becuise It Was Running Bad And Having The Starting Problem Thing.
