Has anyone taken there passanger grab rail of
Discussion in '3rd & 4th Generation 1990-1997' started by Cmkemp92vfr, Sep 8, 2018.
  1. Cmkemp92vfr
    Cmkemp92vfr New Member
    Hernando FL
    I have a 92 Honda vfr 750. My question is has anyone taken the passanger grab rails off the bike. And if so is easy to do. They are kinda ugly in my opinion...
  2. hondaman219
    hondaman219 New Member
    maine usa
    Mine are gone... They tuck under the seat for storage if you want to keep them on the bike. I removed mine for less weight. To remove them you need to remove the tail fairings. There is a bar they slide on. It is bolted to both sides of the sub-frame. Just remove the two bar bolts to remove the grab handles. This is what you remove. 20180909_081040[1].jpg
  3. Cmkemp92vfr
    Hernando FL
    Hondaman219 thank for the info going to take them off today. They just look weird on the.
  4. Blackslide
    Blackslide New Member
    Finland
    If you don't like the looks, just look at the manual. They're on with a single bolt each. Just take out the bolts tuck the handles underneath the seat, put the bolts back in, and put the seat back on, preferrably bolt on the solo cover also. Done.
    If you remove them completely, don't loose them.
    Sent from my PRA-LX1 using Tapatalk
