Grip suggestion for VFR800D
Discussion in '8th Generation 2014-Present' started by icycle2much, May 20, 2015.
  1. icycle2much
    icycle2much New Member
    North Carolina
    Been thinking about removing and replacing the stock grips but before I do I would like to hear from those that have and what they replaced them with.
    What did you replace them with and why?
  2. HondaCrazy
    HondaCrazy New Member
    Pro grip, gel, squishy and comfy
  3. jev.
    jev. over there
  4. TNRabbit
    TNRabbit New Member
    Woodford, VA
    I agree, pro grip are great.
  5. elpaisacq
    elpaisacq New Member
    Pembroke Pines, Florida
    Hello guys... any chance you have the specs for the grips needed...??? it's vfr800 2006
  6. TNRabbit
    TNRabbit New Member
    Woodford, VA
  7. jev.
    jev. over there
    The bars are 7/8". Get some that have open ends to make it easier on yourself. That way you don't have to cut them all jagged like I did.
  8. VFRnewbie
    VFRnewbie New Member
    Devon, UK
    Renthal firm compound original series. Been through a couple of sets and wouldn't use anything else to be honest - but then I like my grips hard, tis what suits you really. It seems lotsa guys like soft gel grips or even waffled mx style soft grips...
  9. icycle2much
    North Carolina
    Thanks for the input
    Since the VFR 800D comes with factory heated grips I am screwed; not unless I wanted to lose that function
  10. Grumpy old man
    Grumpy old man New Member
    New Zealand
    Cambridge, New Zealand
  11. JTC
    JTC New Member
    Watts, CA
    "ol school Factory Honda dirt bike/flat track are pretty much identical to Scott's originals. Been gripping since 1984 for about a 100 bucks and same tube of RTV Orange. However, my gloves go for about $250, 2-4 seasons depending on how many downs I take.
  12. whitedove
    whitedove New Member
    i use 'grip puppies' they're foam and fit over stock, heated grip works fine and it adds just the right amount of cushion, i've used them on all my bikes over the years.
  13. Von 800
    Von 800 New Member
    same; use grip puppies here. like the bigger diameter and are super comfy.
  14. DaHose
    DaHose New Member
    Napa, CA.
  15. rhoderage
    rhoderage New Member
    Nova Scotia
    Progrip 713 for the win, had them on last 2 bikes.
  16. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Oxford Heaterz (Touring) for me ... but I also live in a much colder climate for the early / late seasons. :)
  17. JimHanus
    JimHanus New Member
  18. Von 800
    Von 800 New Member
    grip puppies, here. i keep the heating function, but i get a comfy wider diameter for the hauls.
  19. SlideRule
    SlideRule New Member
    Temecula, CA
    Another +1 for Grip Puppies - I thought the stock heated grips were a bit too hard; slide them puppies on and quite satisfied. Heated grips still work fine and the slightly larger diameter grip is comfy for the long haul. Plus they're cheap and they're not permanent if you don't like them.
  20. stretz1
    stretz1 New Member
    Any one try ODI cush grips?
