Got one of these volt meters
Discussion in 'General VFR Discussions' started by volmann, Dec 1, 2015.
  1. volmann
    volmann New Member
    Johnson City TN
    Instal morrow, looks good and good price at 12.00
  2. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I had a read out with a display like that ... very hard to read in the sunlight.
  3. volmann
    volmann New Member
    Johnson City TN
    its bright
  4. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I thought mine was too ... it wasn't.
    Hopefully, yours is better than the one I had was. Mine was crap in the end. Judging by the photo, it looks like it might suffer from the same 'washout' mine did in direct sunlight.
  5. volmann
    volmann New Member
    Johnson City TN
    Than i get one of these
  6. volmann
    volmann New Member
    Johnson City TN
    Or maybe...I like this one
  7. NormK
    NormK New Member
    The last one isn't much good it is only reading just over 11 volts
  8. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Analog or LCD is the best way to go IMHO ... those digital # ones suck in direct light.
    Some LCD can suck in direct sunlight as well depending on screen.
  9. OOTV
    OOTV Member
    I ended up getting an analog meter and installing it on my '01. It also has a back light so when there's power applied to the leads, it'll light up. I have it setup on a relay so that the switched leg turns on the light as well as allows the meter to read voltage straight from the battery.
  10. Outboard John
    Outboard John New Member
    Escondido, Ca.
    Nice!:cool:
  11. Gator
    Gator Member
    I like the wire strippers out of focus in the background. lol Nice gauge.
  12. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
  13. OOTV
    OOTV Member
  14. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Where'd you get yours from?
  15. OOTV
    OOTV Member
  16. safetypro10
    safetypro10 New Member
    Dallas, TX
    I installed one just like that in the left side panel where that little round cutout is. Bought it from a boat store so its waterproof. Wired direct to accessory fuse block. Turns on with key. Accurate.
    Larry
  17. Lint
    Lint Member
    Simi Valley, Ca.
  18. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Sweet. Thanks guys!
    I think I might order one myself ... been looking at the Lascar EMV 1200 as well.
