Gold Brake Calipers
Discussion in '6th Generation 2002-2013' started by AWP34, Jul 11, 2014.
  1. AWP34
    AWP34 New Member
    Hello All,
    My plan is to go gold on gold as far as brake calipers and forks.
    I wanted to know if anyone had any suggestions on a reasonable pair of Gold Brake Calipers for my 08 VFR 800.
    Brembo is way too expensive. I have seen a decently price pair of NISSIN'S but they are for a CBR 600. Would this be an issue even after changing out the rotors ?
    Tokiko has some for the 09 CBR 1000rr but I haven't seen these too often on any fully assembled CBR 1K's. Would any body know which CBR 1K model these would be on ?
    Thanks again for any information or suggestions.
  2. Scubalong
    What about hunt for the ABS caliper?
  3. AWP34
    AWP34 New Member
    Would I have to do anything on my end as far as the ABS ?
  4. Scubalong
    Just swap out the caliper, the ABS is control by the sensor, ABS rings and computer so no work on your end. If you would try to convert a non ABS to ABS would be a tough. Good luck
  5. AWP34
    AWP34 New Member
    Non ABS
    That's my issue. My VFR is non-abs
  6. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    Like 'Long says, gold calipers from ABS VFR would bolt right on. Thats if you retain the stock forks. If you do a front end swap then you'll have to get calipers appropriate for that set-up.
  7. AWP34
    AWP34 New Member
    Ok so forgive my ignorance. Say I purhase the Nissin calipers that go with the ABS setup for my Non ABS setup and I bolt them on will I have to do anything else to have proper working brakes outside of bleeding the brake lines and ensuring I have brake fluid in the resevoir ?
  8. Arnzinator
    Yep. Look up brake bleeding threads, its a process on LBS bikes.
  9. Scubalong
    Just get the calipers so I can Mount them on for you
    Make sure bring a case of IPA :rolleyes:
  10. AWP34
    AWP34 New Member
    That sounds like a plan. Thanks Scuba
