Gen 3 or later engine in gen 2 chassis?
Discussion in '1st & 2nd Generation 1983-1989' started by hank.sd, Apr 14, 2011.
  1. hank.sd
    hank.sd New Member
    South Dakota
    Anyone ever done that?
    Is it a bolt in deal or not even close.
    Just curious.. thinking about my next project.
  2. JTC
    JTC New Member
    Watts, CA
    Do you already have all the parts, material, time, and skill necessary to perform such a conversion? If not, probably cheaper to buy a 3rd gen, trick it out, and you'd have a superior machine over anything you could achieve with the 2nd gen. There would be very little (if any) practical advantage to installing another generation engine into a generation 2 chassis. :crazy: If you want to do it for bragging rights or just because you think you can, then I understand... I once spent more time and money than I care to admit putting a 90 HP Corvair engine in a VW Bug.:redface:
  3. hank.sd
    hank.sd New Member
    South Dakota
    Yes I have Solidworks 3D modeling and a full machine shop at my disposal. This project would be done for fun and certainly not because it makes practical sense.
    Now that we have that out of the way :) I was just curious if anyone had tried it.
    No I don't have any of the parts at this time, but I do think an EFI 800 Gen 2 would be cool.
  4. hank.sd
    hank.sd New Member
    South Dakota
    Oh and part of this project would be a USD fork, good shock, and 17" wheel transplant. I just did a USD conversion on my Blackbird and love the end result. Even that "small" project was time consuming, so I realize what I be biting off on a project like this. I look at it as 2 or 3 winters worth of entertainment!
  5. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    What is a USD fork? Is this some type of a cartridge emulator?
  6. hank.sd
    hank.sd New Member
    South Dakota
    Oh sorry, up side down (inverted).
  7. JTC
    JTC New Member
    Watts, CA
    Cool. Yes, forget the 3rd gen engine; figure a way to get a 5th or 6th gen EFI 800 engine in there that way you could supercharge it with Toro's kit. A 10 second Generation 2 would be BADD ASSS:cool:
    :vtr2:
  8. supertex
    supertex New Member
    USD forks are too short unless you have longer tubes made.
  9. hank.sd
    hank.sd New Member
    South Dakota
    Might need to find a set of USD forks of a KTM950 or similar and shorten / limit the travel? Would have to be easier than lengthening I'd think?
    I suppose mounting a 17" could get to be a pain then too. Sounds like a challenge ;)
  10. hank.sd
    hank.sd New Member
    South Dakota
    950 super moto? Dual discs, 17" wheel, and the forks have to be fairly long?
  11. JTC
    JTC New Member
    Watts, CA
    I'm excited to follow this build. Obviously, you're going to do the single sided swing arm conversion as well? :smile:
