GEN 1 Idle Adjust with no Guages
Discussion in 'Mechanics Garage' started by anarchy13, Dec 2, 2011.
  1. anarchy13
    anarchy13 New Member
    Germany
    Setting idle speed with no tac? PO stripped this bike of all its guages.
    Now I got another question. Sync first then idle adjust or idle adjust then sync? Thanks
  2. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    It doesn't matter really as long as the motor is about 900-1200 rpms. Once you start the sync you will have to reset idle back down or up to 11/1200 rpms once each carb is adjusted.
    First off do the pilot screw adjustment then sync carbs.
  3. anarchy13
    Germany
    Can I just set the pilot screws to the setting the manual says 2 1/2 turns out and leave em there or is there something else I have to do?
