Gauges work, but no lights on gauges
Discussion in '3rd & 4th Generation 1990-1997' started by OutOfCyan, Jun 30, 2012.
  1. OutOfCyan
    OutOfCyan New Member
    Norfolk, VA
    Hi all,
    I found another issue with my '91 - the gauges don't light up. I think they did when I got the bike, but I'm not sure. The tach didn't work, so I replaced the gauges. The "new" gauges don't light up; seller claims they were working.
    I disconnected the "new" gauges and hooked the old ones back up. They also don't light up.
    Did I leave something disconnected? I see there's a combination meter connector (green) indicated on page 1-34 of the mechanic's manual, but that's for a '94 and later. The wires to the LEDs are green. Does the '91 have that connector as well?
  2. Apittslife
    Apittslife New Member
    Clarksville, Indiana
    Instead of swappin parts, do some trouble shootin.
    A simple test lite, and a couple longer pieces of wire work wonders if you don't have a multi-meter.
    First thing I would check is the bulbs. Then power to the guage light curcuit, from the guage pod to the light switch, of ignition, depending apon where the power is fed from.
    Good luck
  3. safetypro10
    safetypro10 New Member
    Dallas, TX
    Do you have a 3rd gen manual? Download one if not.
    Larry
