Date: April 22, 2011 Cost: $100.00 CDN (shipping included) Purchased: Fuzeblocks.com Manufacturer:Fuzeblocks.com Mod Time: 30 min Part No.: FZ1 I originally purchased the FZ1 Fuseblock back in May 2010 and it was originally destined for my FZ6 but I never got around to installing it (lucky for me). Fuzeblocks.com has designed a fuse block that is easy to install and fits into a small space. The on board relay offers the choice for any device to be switched on or off automatically with the vehicle or to be powered constantly. I found a decent place for it under the seat on the right hand side near the rear brake reservoir. I removed some of the plastic body work in order to make room for it. I found a decent place for it under the seat on the right hand side near the rear brake reservoir. I removed some of the plastic body work in order to make room for it. I wired it as follows: +12VDC - Direct from battery terminal, with an inline fuse (7.5 AMP) that also goes to my SAE plug for charging my battery (Battery Tender). Ground - Spliced into an existing ground wire that I had run to my SAE connector. +12VDC Switched - I tapped in to the the tail light wire so there is only power when the key is in the ON position (Brown/Blue wire). This will sure make it easy to add in additional electronics such as 12VDC outlet, heated grips & clothing, GPS, USB charger, etc. This write up is also on my site here: http://www.bonemanvf...m/Mods/fz1.html - Boneman
