Do you guys know if the Fuse Panel located under the right front panel contains an accessory plug? As part of my winter projects list, I'm installing a Battery Voltmeter and if there is an accessory on the fuse panel, I'll just tie into that for the power lead. I know the Honda Goldwing has two, so I'm hoping the VFR ('07) has at least one. Thanks Guys
Have you downloaded the service manual yet off this site? It has a GREAT wiring diagram that may give you what you need. Heres a link if you dont have it: http://vfrworld.com/forums/parts-se...nloadable-parts-catalogs-service-manuals.html Solid Gold! Good Luck
Haven't taken a close look but the wiring diagram shows the following: Don't think there is an extra in there. Curious how much reserve power there is to add another box or accessories?
