fuel pump issues
Discussion in 'Mechanics Garage' started by pivot, Sep 12, 2011.
  1. pivot
    pivot New Member
    duberlin lreland
    evenin all, havein sum issues with the fuel pump getting power on my 98 800 fi.
    had been driving when it just died on me and the fi light came on, pushed it home( luckily was only about a mile away) managed to start it once or twice on the way but it wouldn't run for more than a minute or two.
    since i got it home i've checked the pump itself with a direct connection to the battery and found it working fine.every connection relay and fuse i could come across seemed fine but still the pump wont run when the on off switch is turned on.
    any suggestions before it goes to a mechanic?
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    check the blue connector. its behind the fairing next to your left knee. there are 2 huge connectors thats have all sorts of shit running through them. including shity grounds. i am currently dealling with this on my 2007...
  3. pivot
    pivot New Member
    duberlin lreland
    problem solved...hopefully,
    turned out to be a couple of bad connections.all cleaned and wd40'd and working fine again.definatly somethin to be checked on a regular basis.
  4. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    yes it is
    i wound up having to cut out the blue connector all together and hard wire all 18 wires together. pain in the ass, but problem solved.
