fuel petcock problem
Discussion in '1st & 2nd Generation 1983-1989' started by volks6000, Jan 2, 2009.
  1. volks6000
    volks6000 New Member
    Jacksonville , Florida
    hey need a little help. smelled gas and found that the petcock was leaking. one side of the pop cast has the head missing. anyone had this happen before and how do you fix it??
  2. VT Viffer
    VT Viffer New Member
    South Carolina
    Yamaha petcocks are similar, but use screws to hold the plate on. Maybe you could drill out the hole, and put a small bolt through it?
    Or you could also get a small screw, and drill / tap the hole into the petcock body.
