Fuel Issues
Discussion in '1st & 2nd Generation 1983-1989' started by cromanyak, Mar 29, 2008.
  1. cromanyak
    cromanyak New Member
    I've got a few issues now with fuel. When I give it gas if I turn the throttle quickly it dies. If I turn it slowly the rpm's rise, but keep rising for a few seconds after I let off the throttle. Also once it got warm gas started leaking from two of the diaphram covers on the carbs, and when I pulled vacuum hose from the block fuel poured out of the vacuum port. Any ideas. I know these might be simple fixes, but I'm new to all this stuff.
    thanks,
    Chris
  2. elf800
    elf800 Banned
    dallas
    sounds like a stuck floatbowl or your slides are sticking and not flowing up and down freely if you know how its carb clean time take off bike all apart clean with b-12 reasemble....good luck do one at a time and take it slow take out main pilot slide needle air screw spray it hard pressure usually they vat carbs ...........
  3. cromanyak
    When you look down through the carbs are the slides those round rubber things? One of those is sticking. Man that was a really close call. It was dumping so much gas into the right front cylinder that it seized. Luckily I was able to take the side cover off and get it unstuck. When I did a bunch of gas shot out of the spark plug hole. I guess it's cleaning time. Woo Hoo :( Good thing I've pretty much mastered the art of removing and installing those things.
    Chris
  4. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    Don't forget to change your oil!! If a cyl was full of gas, some of it surely seeped past the rings and into the oil. Gassy oil is no good.
  5. cromanyak
    I pulled the carbs today and cleaned them. When I got to the last one
    the little plunger on the float needle was completely stuck so that
    must be the problem. I hope it's still available.
    Chris
  6. elf800
    elf800 Banned
    dallas
    your getting there not sure if the gas gets into the engine without it running you know the vacum thing..but hell tune it up anyway new plugs oil airfilter its about to be great wheather so good luck hope you got the answer to your qwestions................
  7. cromanyak
    Thanks. Hopefully the new float needle does the trick. I'm itchin to test ride this thing.
    Chris
