Fuel Gauge readings
Discussion in 'Mechanics Garage' started by OnAnySunday, Aug 6, 2015.
  1. OnAnySunday
    OnAnySunday New Member
    Greetings,
    I recently purchased this fine 94' vfr750 with no issues, the problem started after I filled my tank this one time, did not fill it any different then any other time. Was never dropped.
    Fuel is now reading incorrectly, fuel tank reads below 1/2...
    What could be the problem?
    Cheers,
  2. rjgti
    rjgti New Member
    regina sk
    your float is stuck
  3. Badbilly
    Is there a fix for this? Gotta figure that the "sender" is analog and the instrumentation can be both analog a/o digital.
  4. rjgti
    rjgti New Member
    regina sk
    pull the sending unit outta the tank and check its operation. up will measure 4-10 ohms, down will measure 90-100 ohms
