Fuel gauge erratic
Discussion in 'Mechanics Garage' started by daveyto, Dec 23, 2009.
  1. daveyto
    daveyto New Member
    Scarborough, Canada
    My fuel gauge is sloshing around going up and down at will.
    I have done this repair on an old Merkur xr4ti and it was a failing diode in the cluster...would it be the same thing?
    Its on my 1991 vfr750f
  2. TOE CUTTER
    Most common is the plug from the sending unit has come loose. I would check that first.
  3. daveyto
    daveyto New Member
    Scarborough, Canada
    Where is that under the tank I guess? Or under the gauge itself
  4. TOE CUTTER
    Just behind the tank under the seat, a red plug I think.
  5. daveyto
    daveyto New Member
    Scarborough, Canada
    ok I will check it out!!!
    Thanks again TOE!!!
    your awesome!
  6. TOE CUTTER
    Let me know.:biggrin:
