Front/Rear pad replacement - '98 VFR
Discussion in 'Mechanics Garage' started by desmo907, Mar 16, 2009.
  1. desmo907
    desmo907 New Member
    CT, USA
    I got my front wheel/tire off as it seems to have developed a leak sitting this winter. I notice the pads are getting a bit worn (they are original ~12k miles) so it seems I can easily replace those.
    Should I replace them when the wheel is back on the bike?
    Also, can I easily replace the rear pads while the rotor is attached to the bike?
    (The service manual seems to indicate yes).
    I may bleed the brakes also but the service manual seems to indicate a complicated process.
    On my old (non-linked) bikes I was able to do this rather easily (suck out fluid, add new fluid, open valve, press lever, hold, tighten valve, release lever, repeat.)
    Thoughts?
  2. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    I say do it with the wheels on. I just replaced all 3 rotors worth of pads in about 30 min. And it was my first time. They literally slide right out, compress the pistons, then slid the new ones back in.
