front end problems
Discussion in 'Mechanics Garage' started by Chris71Mach1, Mar 30, 2010.
  1. Chris71Mach1
    Chris71Mach1 Member
    Grand Prairie, Texas, United States
    well crap, now that i have over 52,000 miles on the odometer, and noticing some wierd rattling and clunking in the front end, it seems that i've diagnosed everything down to a failing steering stem bearing.
    at this point, im looking to figure out where i can find a real good quality replacement bearing (ive read that the ball bearing design thats more commonly used isnt all that great and a roller bearing design is far more durable, but i dont know if a roller style steering stem bearing is even available for our bikes).
    next, i need to figure out how the heck to do this job. if anybody has experience replacing this bearing, im all ears at this point, as it really looks like im about to have to jump into this job...
  2. TOE CUTTER
    I did a set last year and I think the brand was All Balls. Not A tough job, remove wheel, forks, upper and then lower triple clamp and remove races and assemble. 4-5 beer job. I would suggest not riding it until repaired as it can cause frame damage if loose enough.The top of the frame above the bearing will get torn up.
  3. squirrelman
    My suggestion is to order OEM bearings from Honda, along with new wheel bearings too.
    Avoid the "AllBalls" brand if you prefer quality over low price.
    Use search feature here as someone posted a really excellent pictorial step-by-step steering bearing reploacement thread semi-recently.
  4. Joey_Dude
    Joey_Dude Member
    North Georgia
  5. supertex
    supertex New Member
    I have the ALL BALLS bearings in mine and have had no issues. I got the tapered roller bearings.
    and yes Squirrel I understand your reservations.
  6. TOE CUTTER
    I always go for factory bearings and not after market .....but not on this one....the factory upper race is very short , thin and prone to cracking and can cause damage to the portion of the frame where it sits and wears into it . The taper cup is twice the height ,providing a much better mounting surface and is way less likely to crack or split.
  7. betarace
    betarace New Member
    Middleburg, VA
    +1 ALL BALLS - best around. Mr. Squirrel's claims are based on bias against china as opposed to real data.
  8. squirrelman
    OH, yes, it's based upon prejudice against broken, inferior, useless Chinese (Communist) tools i've bought that last twice b4 falling apart.
    Some photos are here of "Harbor Freight" broken crap.
  9. betarace
    betarace New Member
    Middleburg, VA
    nice, so predictable
  10. squirrelman
    Predictable= consistant, not a bad thing.
    If you want to cheap out it's fine , just don't claim that you'll get best quality at the lowest price.
  11. Chris71Mach1
    Chris71Mach1 Member
    what part number were the roller bearings? OEM would be nice, but OEM are still the ball type bearings that are known for such wear issues. I'd really like to find a roller style bearing that will fit the steering stem if there's one available.
  12. betarace
    betarace New Member
    Middleburg, VA
  13. Chris71Mach1
    Chris71Mach1 Member
    sweet!!! and after checkin the site, theyre the roller style bearings too! parts bought and hopefully will be shipped & on the way soon!
  14. betarace
    betarace New Member
    Middleburg, VA
    glad we can help! I did mine 3 years ago and have enjoyed every mile since!
  15. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Hey beta:
    I need to make this public record.
    Ya see, S-man never bothered me on when I switched out my bearings becasue I bought some nice German made ones from Thurn Motorsports some time ago.
    But if your "All Balls" ones fail I am never going to let you live it down...LOL!
    (p.s. for those of you who don't know, betarace and I are friends and normally make jests at one another both on and off VFRW).
    BZ
  16. betarace
    betarace New Member
    Middleburg, VA
    feel free. My stockers lasted exactly 3,783 miles and were toasted from track use. The AB replacements have already done 3x that. If they do fail, I will spend the $33 and get a new set. Boo hoo.
  17. Bubba Zanetti
    Delaware
    The reality of your choice in bearings is they say "Balls" on the package!
    BZ
  18. tinkerinWstuff
    sounds like beta's had an issue with his balls in the past. Instead of slapping them around and cracking in short order, he switched to the pinch and roll method.
  19. betarace
    betarace New Member
    Middleburg, VA
    Some balls are held for charity
    And some for fancy dress
    But when they're held for pleasure
    They're the balls that I like best
    My balls are always bouncing
    To the left and to the right
    It's my belief that my big balls
    Should be held every night
  20. reg71
    Sikeston, MO
    I'm all balls myself, too.
    Seem to be lasting just fine for me so far, but I'll be sure to bitch if they mess up...
