fork seal driver
Discussion in 'Mechanics Garage' started by Spike, Nov 27, 2008.
  1. Spike
    Spike New Member
    About to rebuild the front shocks on my '04, and the Honda recomended fork seal driver is part 07947-KA40200. Now from when I had my '98, I have part 07947-KF00100 fork seal driver. Wondering if I can use it. Know this is probly an extremely rare situation, but figured I would ask. Just in case anyone has tried it.
    What I am guessing, and it is certainly a guess, is that the only difference ist that the 5th gen had 41mm forks and the 6th I beleive has 43mm forks. I don't beleive there is any other difference. 2 mm is a pretty small difference, so I am thinking I will be fine, but don't want to ruin $20 in fork seals to save buying a $25 tool.
  2. Gatekeeper
    Gatekeeper New Member
    I use a hunk of PVC pipe. If it pushes on the metal outter ring and not the rubber seal, it will be fine.
  3. squirrelman
    PVC, me too.
    also i use the old seal on top to press in the new one so no damage....
  4. RedMenace
    RedMenace New Member
    DRC, the Congo
    Thanks for the tip
    dude! ten characters from a play I saw, once.
  5. squirrelman
    explication, pleze!
  6. RedMenace
    DRC, the Congo
    This is why I don't like forums
    All I wanted to do was click the "Thank you" button. Then it opened a dialogue box. Then typed, "thankyou" and then it said, "you need 10 characters" and then I was tired of trying to thank someone and typed whatever to keep the forum gods happy. Then it opened a "quick response" box and I just logged off.
    Liked the tip about the diameter of the tube and liked the tip about using the old material. Small details that make a difference to a first attempt.
    Honda Dreams, Bro.
  7. 1983Bob
    1983Bob New Member
    Vancouver Island, BC.
    What size PVC tube do you guys use to install the front fork seals. Thanks!
  8. porcupine73
    porcupine73 New Member
    Yes I find various pieces of pvc fittings useful in doing seals on cages as well. For a few dollars at Home Despot you can pick up all the common sizes, probably one of the cheapest specialty tool kits that can be put together hehe.
