foot peg buzz
Discussion in 'General VFR Discussions' started by super hawk, Jun 3, 2011.
  1. super hawk
    super hawk New Member
    lakeland, fl
    i've had my '07 since dec. when i get between 4 and 5 k rpm, my left foot peg get's a buzz. not very noticeable on the right. once i get over 5, the buzz goes away. everything is tight, is this a common trait with the vfr?
  2. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    Now thats really odd, never heard of it before. I guess it could be a natural frequency resonance, at least thats what it sounds like. I wonder if bolting a piece of metal to the footpeg or bracket would change the natural frequency of the assembly and eliminate the buzz.
  3. 34468 Randy
    I wonder if maybe the feeler thingys on the edge of the foot peg is loose or something. Mine seem to have dissappeared.
    Also those foot pegs are spring loaded. Maybe a short shot of a quality lub into the spring area might resolve this.
  4. VFRGeek
    VFRGeek New Member
    Hickory Flat, GA
    Make sure the mounting bolts are good and tight, the pegs are close enough to the engine to get a certain amount of vibration and can loosen up on you. One of the early things I did to my 2007 was to remove the footpeg bolts and retorque them with some blue Loctite. I don't notice any buzz on mine, but I'm not the most sensitive guy (as my wife will tell you) :rolleyes:
    -VFRGeek
  5. super hawk
    lakeland, fl
    i did not think about unbolting and putting on loctite. i'll give that a try. it's just odd that the right side i only get a slight buzz and the left is very noticealbe. i don't have any on my 996 at all.
