flywheel pull plug size & clutch nut seized?
Discussion in '1st & 2nd Generation 1983-1989' started by RoninWolf, Oct 23, 2014.
  1. RoninWolf
    RoninWolf New Member
    Bolt size & pitch [22mm x 1.5 R.H.] to pull the flywheel, anyone know a simpler way to do it?
    Also, tried for the life of me to loosen the clutch nut but ended up just spinning with the shaft, 120+ ft*lbs. Tried propane torch and PB blasted but no give, anyone else get around this situation?
    Edit:: Found alternator size&pitch
