Floor jack positioning?? On 86 VF500?
Discussion in '1st & 2nd Generation 1983-1989' started by jwf88, Jul 9, 2012.
  1. jwf88
    jwf88 New Member
    I need to replace tires on the 86 vf500 and would like to just bring in the wheels...
    problem is that there isn't a good place under the bike to place the jack.
    The exhaust pipes pass under the frame directly under the engine, and I am not about to use the pipes as a jack surface.
    So my question is how do you do this? A special bike jack? Remove the exhaust? I am interested in knowing how others get around this issue.
    Thanks in advance
  2. smoke4ndmears
    smoke4ndmears New Member
    Maryland
    remove the chin fairing and use a floor jack with a piece of plywood under the oil pan.
  3. jwf88
    jwf88 New Member
    Doing that dosnt seem like it would be stable enough, but if that's what works for you maybe I will try it.
    The oil pan isnt flat and isnt very long. It dosnt seem like the motorcycle would balance on that area. I would post a picture but I dont currently have a camera
  4. Riggy
    Riggy New Member
    Vermont & Long Island
    Put a piece of plywood under the oilpan with a jack stand supporting the bike, with the centerstand down take off the front wheel. Put a jack with a 2x4 under the front fork(where the wheel just was), then remove the rear wheel.
  5. pherako
    pherako New Member
    Houston, TX
    If your garage has rafters, you can just hang the bike from those using ratchet straps. I do that if I need to pull both wheels on the SV650. On the 6gen interceptor, front stand and center stand are enough.
