Flasher relay for LED signals?
Discussion in 'Mechanics Garage' started by crashburn, Jun 8, 2015.
  1. crashburn
    crashburn New Member
    Montréal, Québec
    Hi All,
    Is there a plug and play flasher unit that can be used with LED signal bulbs? Trying to avoid any messy soldering of resistors and such.
    Thanks!
  2. 34468 Randy
    Get the bulb number off your existing bulb and go to the autoparts store. I think they do have bulbs now that do not require the resistors. Your parts man should be able to tell you. I know someone who replaced the signal lights on his travel trailer with LED that did not require the resistors. So I don.t see why you would not be able to get one for your bike.
  3. TNRabbit
    TNRabbit New Member
    Woodford, VA
    Superbrightleds.com has both the replacement flasher & bulbs with a resistor built in. I've have done the business with this company on several occasions and they're fantastic
