Fingers over levers?
Discussion in 'General VFR Discussions' started by jaimev34, Nov 26, 2008.
  1. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Just wondering if you guys keep fingers hovering over the levers while riding. I don't, I keep my hands on the grips, but I've seen pictures of riders who have a finger over the brake lever and a couple of fingers over the clutch lever. I find it uncomfortable to have fingers on the levers while riding. Any thoughts?
  2. Yonan
    Yonan New Member
    TURLOCK, CA
    I keep my fingers on the levers in traffic to get a quiker response time. No traffic around relaxed on the bars. I have small hands so yeah keeping them on the levers is a bit uncomfortable.
  3. Molsan
    Molsan New Member
    Red Deer Alberta
    Well for the skill portion of the test in Alberta a shift is not completed until all fingers return to the grip.
    So standard riding there should be no hover.
    On a race track or constant cornering or anticipation of action can bring on a hover imo.
    Still good practice to return to the grip.
    Also many riders only use 2 finger on the levers when using rather than a full hand. Believe thise to be the best way but is up to the rider.
  4. CARMINE
    CARMINE New Member
    Italy
    (NAPLES) ITALY
    Always fingers on levers. It's something I do since many years when I had a two stroke bike : if the engine begins to block for a lack of lubrication, you will be happy to pull the clutch lever instantly.Just the time to avoid the block of the rear wheel.You know what I mean.
    Ciao and lamps to all VFR owners !
    Carmine
  5. RVFR
    Depends on the environment I'm riding in, bumper to bumper traffic, hell yea, riding a bit aggressive, Yep, but if I'm casually puttzing along, Na...
  6. vfourbear
    vfourbear New Member
    Louisville, KY - Under my tinfoil hat
    Index and middle finger of the right hand on the brake lever about half the time. When in traffic or on a fast ride.
  7. sidlives
    sidlives New Member
    Moab UT
    Index and bird fingers on both levers all the time. It was a pain at first but you get used to it pretty quickly.:strong:
  8. B.Craig
    B.Craig New Member
    Denver, Colorado
    At the MSF Course I took they taught to always cover the Clutch, but to never cover the front break (in normal driving situations).
    The reason they gave is that the rider could give a knee jerk response to a driving event, squeeze down with the right hand in an instant reaction, and go end over end.
    In tight driving situations or a potential breaking situation, I move the fingers out to be ready.
  9. NorcalBoy
    Riding around concentrations of cars, pedestrians, track type riding or on rough roads index finger on front brake to help steady the throttle input and to be prepared for evasive maneuvering. Offroad completely different, index on brake and clutch.
  10. Action
    Action New Member
    Albuquerque
    Same Here.
    Action
  11. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    I might just have to try it for a while to see if it takes. There are some potential benefits. Thanks for all the input.
  12. bitterpil
    bitterpil New Member
    Northern Virginia
    Depends on the contditions. Spirited riding or traffic I keep two fingers on the levers. Crusing down the road, no fingers on the levers.
  13. vwrxtrd
    vwrxtrd New Member
    Loveland Colorado
    Its a habit for me. I find myself covering the levers all the time. Sometimes I have to force myself not to but, always end up with my fingers back on the levers.
  14. Knife
    Knife Member
    Downingtown, PA 19335
    It's automatic for me to cover the clutch lever without even thinking about it, but for some reason, it's not the same for the brake lever, unless I'm in tight traffic, then it's automatic.
  15. Cyborg
    Cyborg New Member
    Fingers in the levers: always in traffic and often on open highway. In addition, I bobbed both levers so I can keep a grip on the bars with the ring and pinkie fingers while working the levers with the index and middle fingers with no problems...
  16. Spectre
    Spectre New Member
    Ohio
    In his book Smooth Riding the Pridmore Way, Reg Pridmore recommends covering both the clutch and the brake with 2 fingers most of the time, so I taught myself this technique, to the point where it felt awkward and unnatural to not cover both levers with the inner 2 fingers of both hands.
    However, I'm merely a street rider with no track schooling, and I eventually discovered (at least for myself) that this technique can be dangerous because in the event of a sudden and unexpected 'Oh shit!!!' moment of panic, my newbie hands would reflexively want to grab down on the handgrips with all fingers in an attempt to 'hold on'. Since I had 2 fingers covering both levers, I would end up suddenly pulling in both the clutch and the brake!
    It didn't take me long to figure out that I had to largely abandon the 2-finger technique, and it took me a while to break this habit. As least for me, having all fingers covering the hand grips is much safer, and it allows my brain to more instinctively and rationally operate both levers by choice rather than by accident.
    I still occasionally use the 2-finger technique in certain situations, but mostly I avoid it. I think it's a technique that may be best suited for the track, but then again I'm a newbie.
  17. MtnRider
    MtnRider New Member
    Sounds like they did not fully explain the MSF portion. In early skill development, typically day one of riding it is recommended to cover the clutch. This is the Basic Riders Course (BRC) and given the "oh shit" times covering the clutch is essential.
    This was my next point. The reason not to cover the brake is for the surprise moments. The natural reaction is to grab and hold on. Grabbing the front brake as most of us know is also the eject button.
    The more practice and skill you have obviously this technique can be adapted to your particular riding habits/style.
  18. powderrecon
    powderrecon New Member
    Seattle
    Always cover the clutch.
  19. 300shooter
    300shooter New Member
    armpit of ontario (Windsor)
    In heavy traffic I cover both, highway , not so much. Either way , try a set of Pazzo levers, I recommend the long clutch , short brake setup, it's amazing how much better they feel and are offset perfect for two finger pulls.
  20. reg71
    Sikeston, MO
    I ride with my fingers on the levers about half the time I think. On the dirtbike it is more than that. Derstuka on the other hand always has at least one finger in his nose...
