Fill level for gas tank
Discussion in '7th Generation 2010-Present' started by kurtfriedrich, Aug 8, 2014.
  1. kurtfriedrich
    kurtfriedrich New Member
    Eastside of Seattle
    The manual says not to go above the plate that is under the opening ... but that leaves a ton of air space. I wouldn't overfill and then park it, but when I am about to set off for a few hundred, what's it going to hurt to go halfway up to the bottom of the opening? It still leaves lots of air, and I'll burn it down in the next 30 minutes.
    Anyone see why this is a bad idea? Makes it a lot easier to get 200 to a tank.
  2. TNRabbit
    TNRabbit New Member
    Woodford, VA
    I always fill mine to just below the brim. Never an issue.
  3. Badbilly
    I never pay attention to any of that shit in the manual either. WTF do those dudes that build the bikes know that I don't?
  4. Scubalong
    Gas expand during temp and elevation change, they just want to be safe to avoid problem with the fuel delivery. If you not riding in extrem weather or elevation you are fine. Ride on and stop worry be happy :wink:
  5. Badbilly
  6. Allyance
    Allyance Member
    Germany
    East Bay, California
    In CA we have vapor recovery nozzles, when I fill up, I manually pull the jacket back to let gas flow, and watch till it get right to the rim. No problem.
  7. ridervfr
    Belgium
    ^ wut he sed aboove, I had a CA model in NJ :sad: :loco: It had that :bs: charcoal canister that got wet when you over filled the tank, also got screwed up if you dropped the bike, (don't ask.)
    They warned you right on the petrol tank not to fill into the filler neck. I learned years later that once one of those canisters was wet from petrol, your basically screwed. My CA bike was a disaster that never ran correctly, (whole other story here.)
    I fill my tanks right up to the rim for what ever its worth.
  8. dynajohn
    dynajohn New Member
    KY
    If guys are filling up to the plate under the filler rim no wonder I hear all the complaints about only getting 130 to 140 miles per tank. After filling to the bottom of the filler rim I Ran back roads yesterday. When I pulled in last night the clock had 164 miles and the gas gauge was showing 2 bars.
  9. Alaskan
    Alaskan Member
    Alaska
    Honda may be worried about liability from damage caused by owners overfilling and having gas overflow the fill opening?
